HPE 16-Port Server Console Switch
Quicklinx: 63VSWS00 Mfr#: AF617A
Looking for a simple and intuitive solution that allows you to access and manage servers in your data center? HP KVM Analog Console Switches allow you to view and manage up to 256 rackmount servers in your data center through a single user interface. HP KVM Analog Console Switches utilize a local On-Screen Display (OSD) interface, accessed through a rack console such as the HP LCD8500, that provides intuitive menus for accessing each attached server or serial managed device. HP G3 KVM Analog Console Switches support an optional USB Remote Access Key that allow you to upgrade to KVM-over-IP functionality, providing remote access and management via the On-Board Web Interface (OBWI). HP KVM Analog Console Switches are available in 4, 8 and 16-Port models. Standard rack mounting of the KVM Console Switch will share 1U (1.75-inch) of front panel rack space with the rack console. However, each model can also be mounted in a "zero U" profile by mounting in the side rails of the rack.
  • View and Manage up to 256 Servers through a Single User Interface
    HPE KVM Analog Console Switches utilize a local On-Screen Display (OSD) that provides access to system-related information such as selected server name, status, power-up test data and configuration menus.G3 models support an optional USB Remote Access Key that allow you to upgrade to KVM-over-IP functionality, providing remote access and management via the On-Board Web Interface (OBWI).Includes Programmable Scanning, a utility that allow you to evaluate system performance by sequentially scanning any or all servers managed through the console switch.
  • 4-Port, 8-Port and 16-Port Models with Multiple Installation and Server Connection Options
    HPE KVM Analog Console Switches include mounting hardware that support "Zero U" installations on both the side and rear of standard IT racks, saving valuable space within your racks.Supports a variety of server connections with interface adapters for PS/2, USB, and VT 100 (serial console support), as well as HPE BladeSystems support via the front diagnostics connector.
  • Secure manageability
    For protection against unauthorized users, HPE KVM Analog Console Switches provide a password option for security purposes.Features support for HPE Location Discovery Services (LDS) and Power Discovery Services (PDS) support when connected to an HPE Intelligent Power Distribution Unit (iPDU) and the HPE LCD8500 1U Rackmount Console Kit (HPE Location Discovery Services LCD8500 Kit required).
HPE Server Console Switch 0x2x16 - KVM switch - 16 ports - rack-mountable
KVM switch - 16 ports - CAT5 - cascadable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
2 local users
On-Screen Display
43.8 cm x 16.5 cm x 4.4 cm
2 kg
ProLiant DL120 G6, DL120 G7, DL165 G7, DL170h G6, DL320 G6, DL360 G7, DL360p Gen8, DL380 G6, DL380 G7, DL380 Gen9, DL385 G7, DL580 G7, DL585 G7, DL785 G6, ML330 G6, ML350e Gen8, SL160z G6, SL170z G6, SL2x170z G6; Rack
KVM switch - 16 ports - cascadable
Enclosure Type
Rack-mountable
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
2 local users
Server Connection Via Twisted Pair
CAT5
Keyboard / Mouse Interface
PS/2
On-Screen Display
16 x KVM RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x network stack device RJ-45 , 1 x USB , 1 x mouse (PS/2) , 1 x keyboard (PS/2) , 1 x VGA HD-15
Internal power supply
43.8 cm
16.5 cm
4.4 cm
2 kg
50 °C
20 - 80%
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Special Server, DL170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL380 G6, DL380 G6 Entry, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 Gen9 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, SL160z G6, SL170z G6, SL2x170z G6 , HPE Rack
63VS C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
