Think how much you use your mouse. That's why we've taken the time to design a wired mouse that is comfortable to use so you can work productively every day - and all day if necessary.
Antimicrobial
Antimicrobial coating helps this mouse meets Chinese standards for antimicrobial testing.
- HP 125 - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- 6.3 cm x 11.2 cm x 3.6 cm
- 80.5 g
- Scrolling wheel
- Cable Length
- 180 cm
- 1-year warranty
- Mouse
- 6.3 cm
- 11.2 cm
- 3.6 cm
- 80.5 g
- Black
Input Device
- Wired
- Interface
- USB
- Cable Length
- 180 cm
- Scrolling wheel
- 1 x USB
- Plug and Play
- Limited warranty - 1 year
