GA-Z97X-SLI Intel® Z97 Chipset
- Supports 4th and 5th Generation Intel® Core™ processors
- Extreme multi graphics support
- SATA Express support for 10 Gb/s data transfer
- M.2 for SSDs drives with up to 10 Gb/s data transfer
- Intel GbE LAN with CFOS internet accelerator software
- Realtek ALC1150 115dB SNR HD Audio with built-in rear audio amplifier
- Long lifespan Durable Solid caps
- APP Center including EasyTune™ and Cloud Station™ utilities
- GIGABYTE UEFI DualBIOS™
Extreme multi-GPU support
Flexible graphics capabilities supported for either CrossFire action, delivering the ultimate in graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution. -
M.2 onboard connector
Gigabyte 9 series motherboards come equipped with an onboard M.2 slot, providing users PCI-Express connectivity for SSD devices. Delivering up to 10 Gb/s data transfer speeds, M.2 offers users considerably faster storage performance than current mSATA and even SATA Revision 3 (6 Gb/s) storage devices. -
SATA Express connector
SATA Express interface provides multiple PCI Express lanes and 2 SATA 3.0 6 Gb/s ports, exposed through the same connector, allowing use of both PCI Express and SATA storage devices. Exposed PCI Express lanes are providing a pure PCI Express connection to the storage device, without any additional layers of abstraction. -
Intel Gigabit LAN
Intel Gigabit LAN networking, a popular choice with gamers that features several performance-enhancing features such as advanced interrupt handling to help reduce CPU overhead and Jumbo Frame support for extra large data packets. -
cFosSpeed
Gigabyte motherboards feature cFosSpeed, a network traffic management application which helps to improve network latency, maintaining low ping times to deliver better responsiveness in a crowded LAN environment. cFosSpeed works in a similar way to an OS driver, monitoring network traffic packets at the application layer, allowing optimization and improved network performance for specific applications. -
Realtek ALC1150 115 dB SNR HD audio
The ALC1150 is a high-performance multi-channel high definition audio codec that delivers an exceptional audio listening experience with up to 115 dB SNR, ensuring users get the best possible audio quality from their PC. The ALC1150 provides ten DAC channels that simultaneously support 7.1-channel sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the front panel stereo outputs. Two stereo ADCs are integrated and can support a microphone array with Acoustic Echo Cancellation (AEC), Beam Forming (BF), and Noise Suppression (NS) technologies. The ALC1150 incorporates Realtek proprietary converter technology to achieve Front differential output 115 dB signal-to-noise ratio (SNR) playback (DAC) quality and 104 dB SNR recording (ADC) quality. -
Built-in rear audio amplifier
Specially designed for gamers, Gigabyte 9 series ultra durable motherboards utilize a high-capacity amplifier which is able to drive 600 O loads, giving gamers a fuller range of dynamic sound with crisper details and less distortion when using high quality professional headphones. -
5x (15µ) gold plated CPU socket design
Gigabyte 9 series motherboards come equipped with a gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins and bad contacts. -
Gigabyte patented DualBIOS (UEFI) design
Gigabyte 9 series ultra durable motherboards feature Gigabyte DualBIOS, an exclusive technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. Gigabyte DualBIOS means that your motherboard has both a "Main BIOS" and a "Backup BIOS", making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process. -
ESD protection for USB and LAN
Gigabyte 9 series motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. Each LAN and USB port is paired with a dedicated protection filter that can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes. -
Power failure protection with anti-surge IC
Gigabyte 9 series ultra durable motherboards also feature special anti-surge ICs that protect your motherboard, and your PC from any surge in power delivery that may occur, helping to ensure that your PC is equipped to deal with any potentially irregular and inconsistent power delivery. -
Humidity protection with Glass Fabric PCB
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. Gigabyte 9 series motherboards have been designed to make sure that humidity is never an issue, incorporating a Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses a PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions. -
Heat sink design
Gigabyte 9 series motherboard features heat sink designs that offer uncompromisingly efficient cooling on key areas of the motherboard including the PWM area and chipset (PCH). Gigabyte 9 series motherboard offers cooling support of the crucial PWM area so even the most aggressive and extreme configurations will be kept well within optimal thermal parameters. -
Gigabyte OPT fan support
Gigabyte 9 series motherboards feature OPT fan support, an additional CPU fan pin header that can be used to connect a water pump and configured for continuous full speed operation. The OPT fan is also useful for high performance coolers employing two fans. -
4K ultra HD support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. Gigabyte motherboards provide native 4K support with integrated Intel HD Graphics via HDMI. -
HDMI - the next generation multimedia interface
HDMI is a high-definition multimedia interface which provides up to 5 Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (high-bandwidth digital content protection), allowing the playback of Blu-ray/HD DVD and other protected media content. -
DVI support
DVI (digital visual interface) is a video interface standard designed for carrying uncompressed digital video data and to maximize the visual quality of digital display devices, such as LCD monitors, digital projectors, and so on. In addition, the DVI interface is compatible with HDCP (high-bandwidth digital content protection).
- Gigabyte GA-Z97X-SLI - 1.0 - motherboard - ATX - LGA1150 Socket - Z97
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC
- Storage Ports
- 6 x SATA-600 (RAID), 1 x SATA-600, 1 x SATA Express port
- USB / FireWire Ports
- 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z97 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1 GB
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 4 x DIMM 240-pin , 1 x CPU , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if PCI Express 3.0 x8 slot is occupied)) , 1 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 1 x DVI-D , 1 x VGA , 2 x USB 2.0 , 4 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header , 1 x parallel - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
- Hardware Features
- DualBIOS, Q-Flash, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, ESD Protection, CFOS Speed Internet Accelerator Software support, GIGABYTE OPT Fan Support, Clear CMOS Button, GIGABYTE Smart Switch
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE Game Controller
- Plug and Play, ACPI 5.0
- 30.5 cm
- 21.4 cm
