GA-H97M-D3H Intel® H97 Chipset
- Supports 4th and 5th Generation Intel® Core™ processors
- Extreme multi graphics support
- HD Audio support
- Highly efficient MOSFET design
- LAN with high ESD Protection
- GIGABYTE LAN Optimizer
- Long lifespan Durable Solid caps
- APP Center including EasyTune™ and Cloud Station™ utilities
- GIGABYTE UEFI DualBIOS™
- Intel® Small Business Advantage
Extreme multi-GPU support
Flexible graphics capabilities supported for either CrossFire action, delivering the ultimate in graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution. -
LAN optimizer - intelligent optimization network management tool
Gigabyte LAN optimizer is designed to allow the user to manage different types of network traffic so that data streams such as HD media, web browsing or online gaming can be prioritized, taking precedence over large data downloads that tend to strangle overall network bandwidth. -
Gigabyte patented DualBIOS (UEFI) design
Gigabyte 9 series ultra durable motherboards feature Gigabyte DualBIOS, an exclusive technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. Gigabyte DualBIOS means that your motherboard has both a "main BIOS" and a "backup BIOS", making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process. -
ESD protection for USB and LAN
Gigabyte 9 series motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. Each LAN and USB port is paired with a dedicated protection filter that can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes. -
Power failure protection with anti-surge IC
Gigabyte 9 series ultra durable motherboards also feature special anti-surge ICs that protect your motherboard, and your PC from any surge in power delivery that may occur, helping to ensure that your PC is equipped to deal with any potentially irregular and inconsistent power delivery. -
Humidity protection with Glass Fabric PCB
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. Gigabyte 9 series motherboards have been designed to make sure that humidity is never an issue, incorporating a Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses a PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions. -
Heat sink design
Gigabyte 9 series motherboards feature heat sink designs that offer uncompromisingly efficient cooling on key areas of the motherboard including the PWM area and chipset (PCH). Gigabyte 9 series motherboards offer cooling support of the crucial PWM area so even the most aggressive and extreme configurations will be kept well within optimal thermal parameters. -
4K Ultra HD support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. Gigabyte motherboards provide native 4K support with integrated Intel HD Graphics via HDMI. -
HDMI-the next generation multimedia interface
HDMI is a high-definition multimedia interface which provides up to 5 Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI is compatible with HDCP (high-bandwidth digital content protection), allowing the playback of Blu-ray/HD DVD and other protected media content. -
DVI support
DVI (digital visual interface) is a video interface standard designed for carrying uncompressed digital video data and to maximize the visual quality of digital display devices, such as LCD monitors, digital projectors, and so on. In addition, the DVI interface is compatible with HDCP (high-bandwidth digital content protection). -
Intel small business advantage
Gigabyte motherboards possess a range of features that are designed to offer vastly improved and simplified control over unmanaged IT infrastructure, with specific focus on security, data backup and raising productivity levels overall.
- Gigabyte GA-H97M-D3H - 1.0 - motherboard - micro ATX - LGA1150 Socket - H97
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel H97 Express
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3 , non-ECC
- Storage Ports
- 6 x SATA-600 (RAID)
- USB / FireWire Ports
- 4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel H97 Express
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz
- Supported RAM Integrity Check
- Non-ECC
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slot(s)
- 4 x DIMM 240-pin , 1 x CPU , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCI
- Storage Interfaces
- SATA-600 - connector(s): 6 x 7pin Serial ATA - 6 Device(s) - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x VGA , 1 x HDMI , 1 x DVI-D , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
- Internal Interfaces
- 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
- Hardware Features
- DualBIOS, Q-Flash, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer, Intel Small Business Advantage support, ESD Protection, Clear CMOS Button, GIGABYTE Smart Switch
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot
- Plug and Play, ACPI 5.0
- 24.4 cm
- 22.5 cm
