WINDFORCE 3X cooling system is equipped with high performance pure cooper heat-pipes which direct touch the GPU can strengthen the speed of heat dissipation. Besides, the air flow is effectively enhanced by the unique blade fan design, this not only increase the cooling capacity while reducing air turbulence but also results a lower noise level.
GIGABYTE Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
- WINDFORCE 3X cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 980 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1178 MHz / BOOST: 1279 MHz
- System power supply requirement: 600W(with two 8-pin external power connectors)
WINDFORCE 3X cooling system is equipped with high performance pure cooper heat-pipes which direct touch the GPU can strengthen the speed of heat dissipation. Besides, the air flow is effectively enhanced by the unique blade fan design, this not only increase the cooling capacity while reducing air turbulence but also results a lower noise level. -
Flex Display technology
GIGABYTE Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy. -
Ultra durable VGA
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. -
Better overclocking capability
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. -
Decrease power switching loss
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
- Gigabyte GV-N980WF3OC-4GD (rev. 1.0/1.1) - graphics card - GF GTX 980 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980
- Memory
- 4 GB GDDR5
- Core Clock
- 1178 MHz
- Boost Clock
- 1279 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 3 x DisplayPort , HDMI , DVI-D (dual link)
- API Supported
- OpenGL 4.4, DirectX 12
- 4.3 cm x 31.2 cm x 12.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1178 MHz
- Boost Clock
- 1279 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 3x, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, GIGABYTE Flex Display Technology
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 256-bit
- Required Power Supply
- 600 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- 4.3 cm
- 31.2 cm
- 12.9 cm
