Gigabyte GeForce GTX 970 4GB PCI-Express 3.0 HDMI OC Mini-ITX Flex
Quicklinx: 9Z55WS00 Mfr#: GV-N970IXOC-4GD
  • NVIDIA GeForce GTX 970
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Measuring merely 17cm in length, the card, specially built for small form factor PCs based on mini-ITX motherboards. Packed with GIGABYTE's unique blade fan design, pure copper heat pipes and patented `Triangle Cool' technology, delivering superior cooling capacity at an extremely low noise level given its compact size.
GIGABYTE Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
  • Powered by NVIDIA GeForce GTX 970 GPU
  • Suitable for Mini-ITX/mATX Builds
  • Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
  • Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
  • BASE: 1076 MHz / BOOST: 1216 MHz
  • Flex Display Technology
  • System power supply requirement: 400W (with one 8-pin external power connectors)
  • Flex Display technology
    Gigabyte Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
  • Ultra durable VGA
    Lower GPU TemperatureUltra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB.
  • Better overclocking capability
    Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
  • Decrease power switching loss
    Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Gigabyte GV-N970IXOC-4GD - graphics card - GF GTX 970 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1076 MHz
Boost Clock
1216 MHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , HDMI , 3 x DisplayPort
API Supported
OpenGL 4.4, DirectX 12
4.3 cm x 18.3 cm x 12.9 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1076 MHz
Boost Clock
1216 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, GIGABYTE Flex Display Technology
Size
4 GB
GDDR5 SDRAM
Bus Width
256-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
4.3 cm
18.3 cm
12.9 cm
