Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics card features a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
GIGABYTE custom-designed cooler
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower. -
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
OC GURU II
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
- Gigabyte GV-N730D5-2GI - graphics card - GF GT 730 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x8
- Graphics Engine
- NVIDIA GeForce GT 730
- Memory
- 2 GB GDDR5
- Core Clock
- 902 MHz
- Effective Memory Clock
- 5 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-D (dual link) , VGA , HDMI
- API Supported
- DirectX 11.2, OpenGL 4.4
- 3 cm x 17.7 cm x 12 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 902 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 3
- API Supported
- Nvidia PhysX-Ready, Ultra Durable 2, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, OC Guru II
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- Software Included
- OC Guru ll
- 3 cm
- 17.7 cm
- 12 cm
