Gigabyte GeForce GT 730 902MHz 2GB GDDR5 PCI-Express 2.0 16 HDMI
Quicklinx: 9NXJWS00 Mfr#: GV-N730D5-2GI
  • High-Definition Multimedia Interface (HDMI)
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics card features a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
  • GIGABYTE custom-designed cooler
    As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • OC GURU II
    Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
Gigabyte GV-N730D5-2GI - graphics card - GF GT 730 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x8
Graphics Engine
NVIDIA GeForce GT 730
2 GB GDDR5
Core Clock
902 MHz
Effective Memory Clock
5 GHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
3
Interfaces Details
DVI-D (dual link) , VGA , HDMI
API Supported
DirectX 11.2, OpenGL 4.4
3 cm x 17.7 cm x 12 cm
Graphics card
Bus Type
PCI Express 2.0 x8
Graphics Engine
Core Clock
902 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
3
Interfaces Details
API Supported
Nvidia PhysX-Ready, Ultra Durable 2, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, NVIDIA Adaptive Vertical Sync, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
64-bit
Required Power Supply
300 W
Software Included
OC Guru ll
3 cm
17.7 cm
12 cm
