Gigabyte GV N630-2GI features Ultra Durable 2, using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 Edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Gigabyte custom-designed 80 mm cooler, with air flow optimized cover and aluminum base. The cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
Ultra Durable 2
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 Edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance. -
Gigabyte custom-designed 80 mm cooler, with air flow optimized cover and aluminum base. The cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise. -
PhysX technology
NVIDIA PhysX is the big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. -
CUDA technology
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performances hungry computing applications. -
NVIDIA 3D Vision
NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
- Gigabyte GV-N630-2GI - graphics card - GF GT 630 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 630
- Memory
- 2 GB DDR3
- Core Clock
- 810 MHz
- Effective Memory Clock
- 1.6 GHz
- Shader Clock
- 1620 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x1536
- Max Monitors Supported
- 2
- HDMI , VGA , DVI-I (dual link)
- API Supported
- DirectX 11, OpenGL 4.2
- 3.6 cm x 18.6 cm x 12.7 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- Shader Clock
- 1620 MHz
- Process Technology
- 40 nm
- Max Resolution
- 2560 x 1600
- 2
- API Supported
- Nvidia GeForce 3D Vision Ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision Surround Ready, GIGABYTE custom-designed 80 mm cooler, Gold plated HDMI, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.6 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 350 W
- Supported Windows 7 Features
- Windows Media Center
- RoHS
- 3.6 cm
- 18.6 cm
- 12.7 cm
