NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
PhysX technology
NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. -
CUDA technology
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. -
NVIDIA 3D Vision
- Gigabyte GV-N610D3-2GI - graphics card - GF GT 610 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 610
- Memory
- 2 GB DDR3
- Core Clock
- 810 MHz
- Effective Memory Clock
- 1.333 GHz
- Shader Clock
- 1620 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x1536
- Max Monitors Supported
- 2
- HDMI , VGA , DVI-I (dual link)
- API Supported
- DirectX 11, OpenGL 4.2
- 2.2 cm x 15.8 cm x 12.15 cm
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- Shader Clock
- 1620 MHz
- Process Technology
- 40 nm
- Max Resolution
- 2560 x 1600
- 2
- API Supported
- Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Gold plated HDMI
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.333 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- RoHS
- 2.2 cm
- 15.8 cm
- 12.15 cm
