Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
- Powered by NVIDIA GeForce GT 610 GPU
- Integrated with the first 1024MB DDR3 memory and 64-bit memory interface
- Core Clock: 810 MHz
- Features Dual-Link DVI-I / HDMI / D-Sub
- Support PCI Express 2.0 bus interface
- System power supply requirement: 300W
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
OC GURU II
An instinctive user interface created for easy monitoring and adjusting all important settings.
- Gigabyte GV-N610-1GI (rev. 2.0) - graphics card - GF GT 610 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 610
- Memory
- 1 GB DDR3
- Core Clock
- 810 MHz
- Effective Memory Clock
- 1.333 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x1536
- Max Monitors Supported
- 2
- Interfaces Details
- HDMI , VGA , DVI-I (dual link)
- API Supported
- DirectX 11.1, OpenGL 4.3
- 2.2 cm x 15.8 cm x 12.1 cm
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- Process Technology
- 40 nm
- Max Resolution
- 2560 x 1600
- 2
- API Supported
- Nvidia PhysX-Ready, Ultra Durable 2, Gold plated HDMI, OC Guru II
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.333 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- Software Included
- OC Guru ll
- 2.2 cm
- 15.8 cm
- 12.1 cm
