Gigabyte GeForce GT 210 590MHz 1GB PCI-Express HDMI
Quicklinx: 86MBWS00 Mfr#: GV-N210D3-1GI
  • High-Definition Multimedia Interface (HDMI)
The N210D3-1GI features gold plated, which is durable large contact area connectors have been used for optimum signal transfer between connections. NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor. NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programers to speed up those performance hungry computing applications.
  • Gold plated HDMI
    Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
  • PhysX technology
  • CUDA technology
Gigabyte GV-N210D3-1GI - graphics card - GF 210 - 1 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce 210
1 GB DDR3
Core Clock
590 MHz
Effective Memory Clock
1.2 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
2
DVI-I (dual link) , VGA , HDMI
API Supported
OpenGL 3.1, DirectX 10.1
2.4 cm x 19.7 cm x 12.1 cm
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce 210
Core Clock
590 MHz
Max Resolution
2560 x 1600
2
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
Required Power Supply
300 W
RoHS
2.4 cm
19.7 cm
12.1 cm
