GA-6PXSVT is a versatile motherboard. It is an optimal choice for workstations handling vast amounts of data, from content-generating machines that need to communicate their output in real time over a network, to workstations that simply need to perform daily backups of several drives over the network. GA-6PXSVT has advanced memory frequency that benefits to high density and memory intensive applications, such as high frequency trading, telecommunication networks, mobile data transfers and so on. This motherboard can also receive several SATA devices to build large storage arrays.
For workstations in 10 Gigabit environments
With an onboard 10 Gigabit Ethernet LAN and a large storage platform, this motherboard is an optimal choice for workstations handling vast amounts of data. From content-generating machines that need to communicate their output in real time over a network, to workstations that simply need to perform daily backups of several drives over the network, the GA-6PXSVT is a versatile motherboard for professionals. -
Faster memory with GIGABYTE
Ready to correspond to industry's standards, GIGABYTE’s engineering has enabled through its capabilities in design, PCB layout and BIOS fine-tuning the support of advanced memory frequency running at higher DIMM population. This is a great feature which will benefit to high density and memory intensive applications, such as high frequency trading, telecommunication networks, mobile data transfers and so on. -
10 Gigabit Ethernet LAN onboard
With virtualized environments asking for considerable resources from the networking side of any system, the GA-6PXSVT is ready for high-performance virtual applications thanks to its 10 Gigabit Ethernet SFP+ controller. Capable of load-balancing, FCoE support and low latency transfers, this solution allows a simplification of a network's topology while boosting its overall performance. -
Digital power control
The GA-6PXSVT includes GIGABYTE’s digital PWM controllers, providing with a dynamic power supply to the processor and memory with a fast response time. Built with advanced calibration tools, they allow to get pure and efficient electrical supply to date. When the CPU workload varies in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This way the CPU operations are stable and the overall reliability of the system is greatly improved. -
SATA Revision 3.0
The GA-6PXSVT can receive several SATA devices to build large storage arrays. -
Support of PCIe Generation 3.0
With the support of PCI Express 3.0 technology directly on the CPU, the GA-6PXSVT is fully configured to provide users with significantly reduced latency and improved data bandwidth to get more of expansion as well as of graphics cards.
- Gigabyte GA-6PXSVT - 1.0 - motherboard - ATX - LGA2011 Socket - C602
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C602
- Processor Socket
- 1 x LGA2011 Socket
- Compatible Processors
- Xeon E5-1600 series, Xeon E5-2600 series, Xeon E5-2600 v2 series, Xeon E5-1600 v2 series
- Max RAM Size
- 32 GB
- RAM Supported
- 8 DIMM slots - DDR3, non-ECC, ECC, registered, unbuffered
- Storage Ports
- 10 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 4 x USB 3.0 + 3 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Graphics
- ASPEED AST2400
- Dedicated Video Memory
- 128 MB
- LAN
- 10 Gigabit Ethernet, 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C602
- Processor Socket
- LGA2011 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Registered, unbuffered
- Single rank, dual rank, quad channel memory architecture, quad rank
- Details
- 8 GB - unbuffered , 32 GB - registered
Graphics
- Graphics Controller
- ASPEED AST2400
- 128 MB
LAN
- Network Controller
- Intel 82574L / 82599EN
- Network Interfaces
- Expansion Slots
- 8 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x CPU
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9230: SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 4 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x LAN (10Gigabit Ethernet) , 2 x LAN (Gigabit Ethernet) , 1 x serial
- Internal Interfaces
- 2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x USB 2.0 - Type A
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- Hardware Features
- Clear CMOS Button
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- 30.5 cm
- 24.4 cm
