With two PCI-Express x16 Generation 3 slots supporting 2-way AMD CrossFireX and NVIDIA SLI modes, this motherboard can receive a duo of GPU working together to deliver ultra smooth utilization of CAD/CAE applications. With the GA-6PXSV3, you can build state of the art workstations that will dramatically speed-up your workflow.
The GA-6PXSV3 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processor and memory with an ultra-fast response time. Built with advanced calibration tools, they allow getting the purest and most efficient electrical supply to date. When the CPU workload varies in function of the applications running, the Intel Turbo Boost Technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPU operations are much more stable, and the overall reliability of the system is greatly improved.
2-way GPU support
With two PCI-Express x16 Generation 3 slots supporting 2-way AMD CrossFireX and NVIDIA SLI modes, this motherboard can receive a duo of GPU working together to deliver ultra smooth utilization of CAD/CAE applications. With the GA-6PXSV3, you can build state of the art workstations that will dramatically speed-up your workflow. -
Digital power control
The GA-6PXSV3 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processor and memory with an ultra-fast response time. Built with advanced calibration tools, they allow getting the purest and most efficient electrical supply to date. When the CPU workload varies in function of the applications running, the Intel Turbo Boost Technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPU operations are much more stable, and the overall reliability of the system is greatly improved. -
Suitable for memory intensive applications
With 4 channels per socket and 3DPC memory architecture, a support of up to 256 GB of 1600 MHz DDR3 memory, and a memory platform of 8 RDIMM/ECC UDIMM slots, the GA-6PXSV3 provides the adequate support for memory intensive applications. -
Support of PCIe Generation 3.0
With the support of the PCI Express Gen. 3.0 technology directly on the CPU, the GA-6PXSV3 is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of expansion cards and graphics cards. -
HD audio
The motherboard is built with a high quality audio chipset providing support to 7.1+2 channels of high definition audio.
- Gigabyte GA-6PXSV3 - 1.0 - motherboard - ATX - LGA2011 Socket - C604
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C604
- Processor Socket
- 1 x LGA2011 Socket
- Compatible Processors
- Core i7, Xeon E5-1600 series, Xeon E5-2600 series (Maximum TDP 150 Watt)
- Max RAM Size
- 256 GB
- RAM Supported
- 8 DIMM slots - DDR3, ECC, registered, unbuffered
- Storage Ports
- 4 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 6 x USB 2.0 + (4 x USB 3.0 via headers)
- Graphics
- ASPEED AST2300
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C604
- Processor Socket
- LGA2011 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 256 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Registered, unbuffered
- Quad channel memory architecture
- Details
- 256 GB - registered - ECC , 64 GB - unbuffered - ECC
Graphics
- Graphics Controller
- ASPEED AST2300
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Intel 82574L
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x4 (x1 mode)
- Storage Interfaces
- SAS -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
- Internal Interfaces
- 4 x USB 3.0
- BIOS Features
- IPMI support, iKVM support
- Hardware Features
- NVIDIA SLI Technology Support, AMD CrossFireX technology support
- 30.5 cm
- 24.4 cm
