Gigabyte AMD Radeon R9 270X 1050MHz 4GB PCI-Express 3.0 HDMI
Quicklinx: 9C4WWS00 Mfr#: GV-R927XOC-4GD
  • AMD Radeon R9 270X
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Gigabyte introduces the exclusive "Triangle Cool" technology to reach a better cooling performance. The patented technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" technology provides a more efficient air flow for the cooling system.
  • Patented "Triangle Cool" technology
  • OC GURU II
    Instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
Gigabyte GV-R927XOC-4GD - graphics card - Radeon R9 270X - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 270X
4 GB GDDR5
Core Clock
1050 MHz
Boost Clock
1100 MHz
Effective Memory Clock
5.6 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , HDMI , DVI-D (dual link) , DisplayPort
API Supported
OpenGL 4.3, DirectX 11.2
4.3 cm x 29.7 cm x 13.2 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 270X
Core Clock
1050 MHz
Boost Clock
1100 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable VGA, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, GIGABYTE WindForce 3x, AMD App Acceleration, Triangle Cool Technology, Graphics Core Next (GCN), OC Guru II
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
5.6 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
Two 6-pin power connectors
Software Included
AMD Catalyst Control Center, OC Guru ll
4.3 cm
29.7 cm
13.2 cm
