Garmin eTrex 10 Bundle
Quicklinx: 8LBBWS00 Mfr#: 010-00970-05
The eTrex 10 retains the core functionality, rugged construction, affordability and long battery life that made eTrex the most dependable GPS device available. You'll recognize the name. You'll recognize the quality.
  • See the way
    eTrex 10 has an enhanced 2.2-inch monochrome display that's easy to read in any lighting situation. Both durable and waterproof, eTrex 10 is built to withstand the elements. Its easy-to-use interface means you'll spend more time enjoying the outdoors and less time searching for information. eTrex 10 features the legendary toughness that's built to withstand the elements - be it dust, dirt, humidity or water, none of which are a match for this storied navigator.
  • Find fun
    eTrex 10 supports geocaching GPX files for downloading geocaches and details straight to your unit. Visit OpenCaching. com to start your geocaching adventure. By going paperless, you're not only helping the environment but also improving efficiency. eTrex 10 stores and displays key information, including location, terrain, difficulty, hints and descriptions, which means no more manually entering coordinates and paper print outs. Simply upload the GPX file to your unit and start hunting for caches.
  • Keep your fix
    With its high-sensitivity, WAAS-enabled GPS receiver and HotFix satellite prediction, eTrex 10 locates your position quickly and precisely and maintains its GPS location even in heavy cover and deep canyons. The advantage is clear - whether you're in deep woods or just near tall buildings and trees, you can count on eTrex 10 to help you find your way when you need it the most.
Garmin eTrex 10 - GPS navigator
GPS navigator
Display
2.2" monochrome - 128 x 160 pixels
Recommended Use
Hiking
USB
Protection
Waterproof
5.4 cm x 3.3 cm x 10.3 cm
142 g
GPS navigator
Recommended Use
Hiking
USB
Aerial
Built-in
Custom POIs, downloadable POIs, preinstalled POIs, hunt/fish calendar, Geocaching, Garmin Connect compatible
Display
LCD - monochrome
Diagonal Size
2.2"
Display Width
3.6 cm
Display Height
4.3 cm
Display Resolution
128 x 160 pixels
Display Illumination
Navigation
Waypoints
1000
Tracks
100
Tracklog Points
10000
Routes
50
USB
Protection
Waterproof
Waterproof Standard
IPX7
5.4 cm
3.3 cm
10.3 cm
142 g
