Fujitsu fi-7600 A4 Document Scanner
Quicklinx: CW1MWS00 Mfr#: PA03740-B501
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 304.8 x 431.8 mm
Interface: USB 3.1 Gen 1
Compatibility: PC
  • Windows 8.1 (32/64 bits)
14 In Stock
£3,356.27 ex VAT
£4,027.52 inc VAT
With scanning speeds of 100 ppm/200 ipm (200/300 dpi), the fi-7600 greatly improves process efficiency. Large volumes of information can be captured from various media types, including thin paper, plastic cards, envelopes and long page documents.
The fi-7600 automatically adjusts to paper weights from 20-413 g/m². The straight paper path reduces the load on a document and assures reliable scanning regardless of the condition and type of a document. By simply sliding a lever to non-separation mode, you can easily scan thick and long documents folded in half, multi-layered document sets and envelopes.
Skew Reducer automatically handles sheets of paper in a stack individually, so that if one sheet is fed-in skewed, subsequent sheets are not forced into physical skew. This ensures that all information in the documents is captured correctly, even in batches with mixed document formats. The Paper Protection function monitors document movement and automatically stops feeding when any irregularities are detected.
The fi-7600 is equipped with an operation panel on both sides allowing for right and left handed use. The LCD on the operation panel reveals the scanner status at a glance and enables instant operation.
The Automatic Document Feeder's (ADF) independent side guides move to exactly the position required for each batch. The adjustable stacker side guides support neat alignment of processed documents.
The fi-7600 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture enhances the document capture process from adjusting scanning settings to performing batch scanning, verifying data and releasing to directories, repositories or subsequent process routines. Users can complete data capture tasks easily with the extremely user-friendly graphical user interface (GUI). Moving scanned batches into a queue for later retrieval is possible as well.
  • Scan various types of business documents with a single scanner
    The straight paper path design provides reliable scanning regardless of the condition and type of paper.
  • Protect important information by preventing missing edges and document damage
    Skew Reducer helps improve the feeding performance significantly and prevents a scanned image from missing an edge.
  • Fully utilize allocated space with its flexible design
    The fi-7600 is equipped with operation panels on both the right and left sides of the scanner so that it can be easily accessed in any office or workspace environment. An LCD on the operation panel allows the status of the scanner to be easily verified.
  • Reduce the workload before and after scanning from setting to collecting documents
    When setting documents, you can easily align the edges of the documents with independent Side Guides even if the size of each document varies.
Ricoh fi-7600 - document scanner - desktop - USB 3.1 Gen 1
Document scanner - desktop
Interface Type
USB 3.1 Gen 1
Scanning Sensor Type
Dual CCD
Light Source
White LED array
Additional Functions
Scan to SharePoint
Max Supported Document Size
304.8 x 431.8 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
304.8 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, envelope, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
30000 scans per day
AC 120/230 V
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
23.6 cm x 43.2 cm x 21.4 cm
11 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 3.1 Gen 1
Scan to SharePoint
304.8 x 431.8 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
30000 scans per day
Scanner Speed Details
100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 80 ppm - portrait - A4 - 200 dpi , 80 ppm - portrait - A4 - 300 dpi , 160 ipm - duplex - portrait - A4 - 200 dpi , 160 ipm - duplex - portrait - A4 - 300 dpi
Scanner Features
Paper Protection Function, Image Emphasis, Long Paper Mode, Dynamic Threshold, Error Diffusion, Barcode Detection, Ultrasonic multifeed sensor, automatic colour detection, Dither, Advanced DTC, Multi-Image Output, built-in LCD screen, RGB Color Dropout, Punch Hole Removal, Deskew, Blank Page Detection
TWAIN, ISIS
Media Handling
Max Document Size
304.8 mm x 5588 mm
Supported Document Size Details
ADF - up to 304.8 x 431.8 mm , Long document - up to 304.8 x 5588 mm
Automatic
300 sheets
Interfaces Details
USB 3.1 Gen 1 - Type B
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
64 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
1.7 Watt
Software Included
Drivers & Utilities, ScanSnap Manager, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture, 2D Barcode for PaperStream, Error Recovery Guide
23.6 cm
43.2 cm
21.4 cm
11 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
CW1M Fujitsu Extends Warranty From 1 Year to 3 Year For Low Volume Production Scanners - NBD Onsite In Stock £871.31
CW1M Fujitsu Extends Warranty to 3 Year with 8+8hrs On-Site Fix for Low Volume Scanners - Onsite 8 Hours In Stock £1,108.54
CW1M Fujitsu Extends Warranty 3 Years with Low Volume Production Scanners - 8+8hrs On-Site 1 x PM In Stock £2,217.09
CW1M Fujitsu Extends Warranty 3 Years Low Volume Production Scanners 8+8hrs On-Site 2 x PM In Stock £3,403.21
CW1M Fujitsu Extends Warranty 3 Years Low Volume Production Scanners - 8hrs On-Site + 8hrs Fix 3 x PM In Stock £4,770.90
CW1M Fujitsu Scanner Consumable Kit: 3740-500K In Stock £274.04
CW1M Fujitsu F1 Scanner Cleaning Kit In Stock £40.08
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: £1500+
