The flatbed-equipped fi-6770 is amongst the fastest scanners in its class, able to capture documents at 90ppm / 180ipm capable (A4, landscape, 200 dpi). Its 200 sheet document feeder allows continuous scanning containing paper of different weights, quality and sizes and the fi-6770 can even scan paper up to 3 m long enabling digitization of electrocardiograms, instrumental data readings and other long documents.
Extremely compact design features an automatic document feeder that can be rotated up to 180° giving wider options for positioning the scanner in the office. For example it can be placed against a wall or in a corner without affecting performance or reducing operational comfort. This also ensures equal ease of use for left and right-handed operators.
The fi-6770 comes loaded with features allowing the scanner to work autonomously as a true batch document scanner. Intelligent multi-feed function simplifies pre-scanning preparation and improves efficiency by identifying documents that tend to trigger false multi-feed alerts, such as documents with photos or sticky notes attached. The fi-6770 scans trapezoid-shaped documents across their full width, as well as ensuring that index tab and sticky note attached documents are scanned in their entirety. In addition, the fi-6770 removes the circular and angular punch hole representations that are created from scanning loose-leaf sheets, courier service forms and other similar documents.
Excellent scanning performance is possible with the bundled premium version of ScandAll PRO V2 scanning software, which features embedded zonal OCR functionality, multi-streaming options and a wealth of output format including password protected PDF and PDF/A formats. In daily operation tasks the user can be supported by setting up job routine profiles that can easily be ex- and imported by multiple scan stations. ScandAll PRO V2 Premium features job separation and indexing functionality using 2D codes (matrix codes).
The bundled ScandAll PRO image capture software supports advanced functions such as Automatic Job separation, Indexing, Seamless Microsoft Office SharePoint Server linkage and Scanner Central Admin console for network enabled device management.
The fi-6770 comes bundled with Kofax Software VRS Professional, which simplifies the image capture operation and streamlines automated business processes. It allows information workers to focus on their productive tasks whilst at the same time supporting them by capturing information from paper documents at the click of a button.
Advanced scanning intelligence, high reliability, increased productivity
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6770 production scanner. Designed with outstanding paper handling, high scan speeds of up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6770 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6770's innovative intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents such as photos, label stickers, or taped-on receipts. -
High-impact scanning, low environmental impact
In keeping with Fujitsu's long-standing commitment to safeguarding the environment, the fi-6770 is the business scanner to adhere to strictest ecological regulations throughout the entire manufacturing process. The design and manufacture of the fi-6770 meet Energy Star's energy consumption requirements and the European Union's Reduction of Hazardous Substances and Volatile Organic Compounds regulations.
- Fujitsu fi-6770 - document scanner - desktop - USB 2.0, SCSI
- Document scanner - desktop
- Interface Type
- USB 2.0, SCSI
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- ANSI B (Ledger) (279 x 432 mm)
- Input Type
- Grayscale / Color Depth
- 10-bit grey
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 90 ppm (mono) / 90 ppm (colour)
- Max Document Size
- 279 mm x 432 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- 50 cm x 69 cm x 34.3 cm
- 35 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0, SCSI
Scanner
- Input Type
- Grayscale Depth
- 10-bit grey
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- CCD
- Max Document Scan Speed B/W
- 90 ppm
- Max Document Scan Speed Colour
- 90 ppm
- Duty Cycle
- Scanner Speed Details
- 90 ppm - black & white , 90 ppm - colour , 180 ipm - duplex - black & white , 180 ipm - duplex - colour
- Scanner Features
- Ultrasonic Double Feed Detection
- TWAIN, ISIS
Media Handling
- Max Document Size
- 279 mm x 432 mm
- Plain paper
- Automatic
- 200 sheets
- Interfaces Details
- Ultra SCSI - HD-68 , USB 2.0 - Type B
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 216 Watt (6 Watt)
- Software Included
- Drivers & Utilities, QuickScan (Demo), Adobe Acrobat Standard, ScandAll Pro, Soft IPC (demo), Kofax VirtualReScan 5.0 Professional
- 50 cm
- 69 cm
- 34.3 cm
- 35 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 53 dB
