The fi-5015C image scanner from Fujitsu with a USB interface offers high speed, simplex color scanning capabilities within a compact body making it an ideal solution for decentralized scanning applications.
The fi-5015C can be customized to scan directly to email, ftp, print, Adobe PDF, or view with hardware profiles.
Equipped with a powerful 600-dpi true optical resolution CCD sensor, the Fujitsu fi-5015C dual feed scanner captures your document's finest details in both 24 bit color and monochrome. The fi-5015C automatic scanner also features an operator panel allowing effortless scanning directly to print, an email attachment, FTP, Adobe PDF, network share, or to your viewer.
Adobe Acrobat Standard and ScandAll Pro are included with the Fujitsu fi-5015C scanner, which allow you to quickly and easily integrate it into your workflow.
Customize the Fujitsu fi-5015C to scan directly to email, ftp, print, Adobe PDF, or view with hardware profiles
The Fujitsu fi-5015C scanner's small footprint and advanced feature set make it an ideal solution for decentralized scanning applications. -
Fast, flexible, reliable scanning performance
- Fujitsu fi-5015C - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 15 ppm (mono) / 15 ppm (colour)
- Max Document Size
- 216 mm x 356 mm
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista
- 44.5 cm x 33.2 cm x 17.9 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- CCD
- Max Document Scan Speed B/W
- 15 ppm
- Max Document Scan Speed Colour
- 15 ppm
- Scanner Speed Details
- 15 ppm - colour - 150 dpi , 15 ppm - black & white - 200 dpi , 15 ppm - greyscale - 200 dpi
- TWAIN, ISIS
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 24 Watt (6 Watt)
- Software Included
- Adobe Acrobat Standard
- OS Required
- 44.5 cm
- 33.2 cm
- 17.9 cm
- 5.5 kg
- 5 °C
- 35 °C
- 10 - 85%
