- Fujitsu - DDR3 - module - 8 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Dual rank, registered
- Designed For
- PRIMERGY RX200 S6, RX300 S6, TX200 S6, TX300 S6
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Fujitsu PRIMERGY RX200 S6, RX300 S6, TX200 S6, TX300 S6
