Designed to be the ultimate in simplicity, the easy-to-use AX650 features a 16-megapixel CCD sensor that captures large, high quality images, a precision Fujinon 5x optical zoom that Lens brings the action closer, and a bright 2.7" LCD makes shooting and viewing a snap. The AX650 also features the SR AUTO function which allows the camera to automatically determine difficult shooting conditions and maximize performance, for a great shot time after time. Combine all this with the convenience of AA battery operation for a simple to use value solution for the everyday picture taker.
Fujinon 5x zoom lens and 14 megapixels
Fujinon lens, the high precision optic lens from Fujifilm, has received positive praise when used in various industries - satellite in outer space, TV/film, surveillance, and compact cameras. The technology provides great wide angle (1x) and 5x optical zoom. -
High sensitivity ISO3200
With maximum sensitivity of ISO3200, photos appear natural and more true-to-life even with limited available light. High sensitivity also stops the action of high-speed moving subjects. -
Digital image stabilization
Automatically detects blurred subjects and instantaneously increases shutter speed to ensure crisp, sharp images. -
2.7-inch monitor
Brighter LCD screen gives you vivid color reproduction and is easier to see in outdoor situations. Sharing pictures is a pleasure, thanks to a high-impact 230,000-dot resolution.
- Fujifilm FinePix AX650 - digital camera - Fujinon
- Product Type
- Digital camera - 720p - compact
- Lens Included
- Fujinon
- Memory Card Slot
- SD card
- Sensor Resolution
- 16.0 Megapixel
- Max Video Resolution
- 1280 x 720
- Lens System
- Zoom lens - 5x zoom - 5.9 - 29.5 mm - f/3.3-5.9
- Focus Adjustment
- Automatic
- Min Focus Distance
- 45 cm
- Digital Zoom
- 7.2x
- Image Stabiliser
- Electronic
- Camera Flash
- Built-in flash
- Display
- LCD display - 2.7"
- Supported Battery
- 2 x AA alkaline battery (included) , AA NiMH rechargeable battery (optional)
- Interface
- Composite video/audio, USB 2.0
- Red
- 9.3 cm x 2.78 cm x 6.02 cm
- 119 g
- Product Type
- Lens Included
- Fujinon
- Enclosure Colour
- Red
- Sensor Resolution
- 16.0 Megapixel
- Optical Sensor Type
- CCD
- Effective Sensor Resolution
- 16,000,000 pixels
- Optical Sensor Size
- 1/2.3"
- ISO (Max)
- 3200
- Optical Zoom
- 5x
- Digital Zoom
- 7.2x
- Image Stabiliser
- Electronic
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
- Auto Focus
- TTL contrast detection
- AE/AF Control
- Subject-tracking AF
- Face Detection
- Blink Detection technology, Smile Capture
- Digital Video Format
- AVI, MJPEG
- Image Recording Format
- JPEG
- 1280 x 720
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto, ISO 3200 (4MP)
- Exposure Metering
- Multi-segment
- Exposure Metering Zones
- 256
- Exposure Modes
- Programme, automatic
- Shooting Programs
- Landscape, portrait mode, night mode, text, party/indoor, fireworks, flower, sports mode, sunset, beach, night (tripod), natural light, snow, baby, natural light & with flash, smile shot, motion panorama
- White Balance
- Automatic, presets
- White Balance Presets
- Fine, incandescent, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
- Max Shutter Speed
- 1/1400 sec
- Min Shutter Speed
- 8 sec
- Exposure Compensation
- ±2 EV range, in 1/3 EV steps
Lens System
- Fujinon zoom lens - 5x zoom - 5.9 - 29.5 mm - f/3.3-5.9
- Focal Length Equivalent to 35mm Camera
- 33 - 165mm
- Focus Adjustment
- Automatic
- 45 cm
- Macro Focus Range
- 10cm
- Zoom Adjustment
- Motorised drive
- Lens Construction
- 8 groups / 8 elements
- Built-in lens shield
Camera Flash
- Camera Flash
- Built-in flash
- Flash Modes
- Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- Effective Flash Range
- 0.6 m - 4.2 m: ISO auto (wide lens) , 0.6 m - 2.8 m: ISO auto (tele lens) , 0.3 m - 1 m: ISO auto (macro lens)
Additional Features
- Self-Timer Delay
- 10 sec, 2sec
- Additional Features
- RGB primary colour filter, digital image rotation, in-camera red-eye removal, cropping an image, resizing an image, Automatic Scene Recognition (SR Auto), Motion Panorama
Display
- 2.7" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , Composite video/audio output
Software
- Software
- Drivers & Utilities
- Included Accessories
- Hand strap, USB cable
- Battery Type
- AA - Alkaline - standard form factor
- Details
- Battery Life Details
- Photo shooting - 160 shots (alkaline batteries) , Photo shooting - 420 shots (NiMH batteries)
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Image Storage
- JPEG 4608 x 3440 , JPEG 4608 x 3072 , JPEG 4608 x 2592 , JPEG 3264 x 2448 , JPEG 3072 x 1728 , JPEG 2304 x 1728 , JPEG 1920 x 1080
- Video Capture
- AVI - 1280 x 720 - 30 fps , AVI - 640 x 480 - 30 fps , AVI - 320 x 240 - 30 fps
- 9.3 cm
- 2.78 cm
- 6.02 cm
- 119 g
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
