Nowadays, most computers and notebooks are shipped without a floppy drive. However, the need for a floppy drive still exists; the old, trustworthy 3.5" floppy disk is still one of the most used media types in the world. Small files like drivers, software updates, patches for operating systems, anti-virus updates and boot-diskettes are still being shipped on floppy disks. Also, a lot of people still have old text files, spreadsheets, pictures, etc. saved on floppy disks. So there will always come a time when you need a floppy drive for a software update, to access some of your old data, or you need a diskette to quickly save a small file on.
The Freecom External USB Floppy Drive is all that you need. Affordable, easy to use, lightweight: very portable and very convenient. Installing the USB floppy drive could not be easier: just plug it into the USB port of your computer and you're ready to go! The Freecom External USB Floppy Drive is also a very cost-effective replacement for when your existing floppy drive is broken. Powered through your USB port, this USB floppy drive gets you up and running in seconds.
- Freecom floppy disk drive - USB
- Floppy disk drive
- Enclosure Type
- External
- Enclosure Colour
- Black
- Interface
- USB
- 10.3 cm x 14.2 cm x 1.7 cm
- 280 g
- Storage Removable
- Floppy Disk
- Storage Removable Capacity
- 1.44 MB
- Media Type
- Floppy Disk - 3.5"
- OS Required
- Apple MacOS 9.0 or later, Apple MacOS X 10.x, Microsoft Windows 98SE/2000/ME/XP
- 2 years warranty
- Floppy disk drive
- Enclosure Type
- External
- Enclosure Colour
- Black
- Interface
- USB
- 10.3 cm
- 14.2 cm
- 1.7 cm
- 280 g
Storage Removable
- Floppy Disk
- Capacity
- 1.44 MB
- Media Type
- 1 x USB - mini-USB Type B
- Media Included Qty
- 2
- Cables Included
- 1 x USB cable
- MTBF
- 30,000 hour(s)
- CSA, UL, TUV
- Software Included
- Driver, F-Secure Internet Security 2004 (Trial), Roxio PhotoSuite (Trial)
- OS Required
- 2 years warranty
- Service & Support Details
- Limited warranty - 2 years
- 5 °C
- 50 °C
- 8 - 80%
Customer reviews
Write a review for the Freecom USB2 Floppy Disk Drive here!
Compact, 2 free discs
Reviewed by MikeG. Review Posted 28/08/2008
Just replaced a Sony USB floppy drive with this model. Seems to be more compact. Bonus was it came bundled with two blank floppy discs :-)
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
