Freecom DAT-160 Int USB 80-160GB Bare
Quicklinx: 550MWS00 Mfr#: 29766
The internal Freecom DAT-160i SCSI Tape Drive is a reliable, reasonably priced backup solution for small to medium-sized servers and high-end workstations. The drive is the ideal solution for all high-volume applications.
Freecom TapeWare DAT 160i - tape drive - DAT - USB 2.0
Tape drive
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
USB 2.0
14.5 cm x 18.3 cm x 4 cm
1.2 kg
Storage Removable
DAT - 5.25" x 1/2H
Storage Removable Capacity
80 GB (native) / 160 GB (compressed)
Supported Tape Cartridges (Read and Write)
DDS-4, DAT-72, DAT-160
Data Transfer Rate (native)
6.9 MBps (25 GBph)
Data Transfer Rate (compressed)
13.8 MBps (49.7 GBph)
3-year warranty
Tape drive - DAT
Recording Standard
DAT-160
Enclosure Type
Internal
Interface Type
USB 2.0
Enclosure Colour
14.5 cm
18.3 cm
4 cm
1.2 kg
Storage Removable
DAT - 5.25" x 1/2H
Recording Standard
DDS-4, DAT 72, DDS-5, DAT 160, DDS-6
6.9 MBps (25 GBph)
Average Seek / Access Time
50 sec
Buffer Size
16 MB
1 x USB 2.0
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
Cleaning cartridge
TUV, VCCI, C-Tick, BSMI, EN 60950, RRL, IEC 60950, CISPR 22, CSA 22.2 No. 60950, FCC, RoHS
Package Type
Bulk
Limited warranty - 3 years
5 °C
20 - 80%
