The DAT 160 extends the professional storage series of Freecom by a drive that can store a total of 80 - 160 GB of data (compressed 2:1) on a single disk, and therefore offers more than twice the memory capacity of the predecessor model. The drive is only half the height, and is also downwards-compatible with the two previous models DAT 72 and DDS 4. The data transfer rate is up to 49.3 GB/hour (compressed 2:1). The "One Button Disaster Recovery" (OBDR) function enables easy and fast system restoration.
- Freecom tape drive - DAT - USB 2.0
- Tape drive
- Recording Standard
- DAT-160
- Enclosure Type
- External
- Interface Type
- USB 2.0
- Storage Removable
- DAT
- Storage Removable Capacity
- 80 GB (native) / 160 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- DDS-4, DAT-72, DAT-160
- Data Transfer Rate (native)
- 6.9 MBps
- Data Transfer Rate (compressed)
- 13.8 MBps (49.3 GBph)
- OS Required
- Linux, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003
- 3-year warranty
- Tape drive - DAT
- DAT-160
- Enclosure Type
- External
- Interface Type
- USB 2.0
Storage Removable
- DAT
- Capacity
- DAT 160
- 6.9 MBps
- 1 x USB 2.0
- Package Type
- OEM
- Software Included
- HP TapeAlert
- OS Required
- Limited warranty - 3 years
