Fractal Design Tesla R2 series power supply units provide clean power efficiently and quietly. The Tesla R2 is an excellent choice for demanding high-end gaming computers and powerful workstations. The visual appearance of Tesla R2 series PSUs is proof of Fractal Design's commitment to providing innovative computer components infused with stylish, elegant, contemporary Scandinavian design.
80 PLUS Gold certified efficiency
Tesla R2 series PSUs meet the 80 PLUS Gold specification for providing power with an efficiency that surpasses most power supplies available today. This efficiency produces positive environmental impact, as well as reduces electricity bills. Additionally, because Tesla R2 PSUs generate less heat, they provide power at lower fan speeds, which results in reduced noise levels. -
Excellent electrical performance
Tesla R2 series PSUs feature excellent DC voltage regulation and ripple suppression; they can deliver their full-rated wattage continuously even with an intake temperature as high as 40 °C. -
SLI and CrossFireX support
Tesla R2 series PSUs (650 W and up) are tested and certified compatible with the latest graphics cards. -
Silent, temperature-controlled 135 mm fan
Generally, larger fans move more air with less noise than smaller fans: Tesla R2 series PSUs are equipped with a large, low-speed, 135 mm fan, which keeps noise level down. -
Single powerful 12 V rail
To provide maximum support for modern components, Tesla R2 series PSUs deliver their full power from a single 12 V rail. -
Extra-Long ATX12V cable
Tesla R2 series PSUs are equipped with a 700 mm long 12 V ("P4") connector cable, which accommodates bottom-mounted-PSU computer cases.
- Fractal Design Tesla R2 - power supply - 500 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.31
- 80 PLUS Certification
- 80 PLUS Gold
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V - 41.5 A , -12V - 0.5 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 5 x 15 pin Serial ATA power , 2 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties
- Black
- 15 cm x 16.5 cm x 8.6 cm
- 3-year warranty
- ATX12V 2.31
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- 80 PLUS Gold
- Cable ties
- Cables Included
- Power cable
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- SLI ready, single 12V rail, temperature controlled fan, ball bearing cooling fan, CrossFireX ready
- Limited warranty - 3 years
- 15 cm
- 16.5 cm
- 8.6 cm
- Shipping Width
- 10.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 26 cm
