Ezviz EB8 4G Outdoor Battery Pan/Tilt Camera
Quicklinx: H593WS00 Mfr#: CS-EB8-R100-1K3FL4GA
Type: Outdoor Camera
Compatible With: Alexa, Google Assistant
  • microSDHC Card
  • microSD Card
22 left in stock
£124.99 ex VAT
£149.98 inc VAT
Express delivery Delivered on Tuesday
Make 360° protection mobile and reliable
Now, it’s easier than ever to put security in action in the places you care about most. EZVIZ’s newest camera overcomes installation limitations caused by networks or electricity. The EB8 4G is battery-powered with no strings – or cords – attached. It operates on 3G/4G LTE networks in the outdoors where Wi-Fi may not be available. It also inherits key features from EZVIZ's popular outdoor pan & tilt predecessors to provide smart and reliable protection 24/7.
Made for the great outdoors
Wi-Fi and power can be a headache when it comes to outdoor protection. The EB8 4G changes the game by operating with a large battery and 4G network. The camera is weatherproof against rain and snow, and can stay charged using sunlight through a compatible solar panel.
With 4G, it’s portable & mobile
Wi-Fi coverage will no longer be a problem when finding that perfect location to install the EB8 4G. Just install the camera any place with a 4G LTE connection, and move it to another spot whenever you need.(1)
Know where your camera is with the built-in GPS
Even if you lose your camera in the wilderness or the woods, it won't be lost thanks to the GPS locator function
Large battery capacity, with eco-friendly charging options
The EB8 4G is 100% wire-free with built-in rechargeable batteries (3). Going even further into the realm of sustainable green energy, this camera can be connected to an EZVIZ Solar Panel (4) to harness the power of the sun
1 Please note that the EB8 4G camera only operates with a 4G network and does not work with a Wi-Fi connection. The list of supported regions and carriers is continually updated; please find the full list at ezviz.com. 2 The GPS function is able to run properly only when the camera is installed in an open, outdoor environment. If you install the camera in an indoor space inside a building, the GPS may not function properly. 3 The camera battery life may vary due to the stability and/or signal strength of network carriers, environmental factors, and the frequency of camera activities. 4 The solar panel is not included in the kit. Currently the EZVIZ EB8 4G supports connecting with EZVIZ’s specific solar panels with type-C charging ports. Please verify compatibility before making a purchase. 5 Local storage cards must be purchased separately. Cloud storage service is only available in certain markets. Please verify availability before making any purchase. 6 The spotlight will not flash when the Color Night Vision mode is enabled. 7 Data from EZVIZ Lab’s test results under standard conditions. The video compression efficiency will vary with the frequency and complexity of the activity captured, as well as other environmental factors
  • Made for the great outdoors
  • With 4G, it's portable and mobile
  • Know where your camera is with the built-in GPS
    Even if you lose your camera in the wilderness or the woods, it won't be lost thanks to the GPS locator function.
  • Large battery capacity, with eco-friendly charging options
    The EB8 4G is 100% wire-free with built-in rechargeable batteries. Going even further into the realm of sustainable green energy, this camera can be connected to an EZVIZ Solar Panel to harness the power of the sun.
  • A sharp, smart eye that goes around your property
    The EB8 4G is designed to provide smart notifications on detected activities. You can set the camera to detect all kinds of motion - including running animals - or enable the smart human motion feature to auto-track human activities.
  • 360° plus 2K for far less blind spots
    A bigger space needs a wider view, and that's where the EB8 4G comes in handy. It can pan and tilt to take in a 360-degree field-of-view, and render details in 2K resolution to capture crucial moments clearly.
  • One click return to the preset location
    No matter how complicated the tracking is, the camera always knows its way back to your preferred viewing angle. You can pinpoint up to 12 angles via the EZVIZ App. Just click on your pre-set dots and the camera will automatically resume its place.
  • See every detail in color, from day to night
    Black-and-white images are now history. The EB8 4G uses its built-in spotlight to restore the colorful beauty of its natural surroundings, even when it's late at night. It would be very difficult to sneak in under the cover of darkness with the EB8 standing guard.
  • A vigilant guard who works around the clock
    The camera features an active defense function to provide an extra layer of protection. Upon detection of intruders, the camera will flash a spotlight to let uninvited visitors know they have been detected.
  • Speak to uninvited visitors using just your smartphone
    Enjoy two-way communications by simply using your phone. Or, pre-record specific voice messages that automatically play when people are detected on camera.
  • Smart integration, hands-free control
    Easily manage your EB8 4G via the EZVIZ App. What's better, you can voice-enable the live viewing with "Hey Google" or "Alexa" to check what's happening on a bigger screen.
EZVIZ EB8 4G - network surveillance camera
Network surveillance camera - pan / tilt - outdoor - weatherproof
Audio
Yes: two-way audio capability
18.3 cm x 11.6 cm x 16.6 cm
835 g
Wireless
Camera
Colour - Day&Night
Max Resolution
2304 x 1296
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
2K
Optical Sensor Type
PS CMOS - 1/2.8" - 3 MP
Minimum Illumination
0.01 lux F1.6 - AGC on , 0 lux - IR
Panning Range (degree)
340
Tilting Range (degree)
65
LTE
Intelligent Assistant
Google Assistant, Alexa
1 - USB-C cable - external
Voltage
DC 5 V
GPS ready, password protection, auto tracking, built-in siren, panoramic view, infrared-cut filter, Colour Night Vision, watermark, anti-flicker, 3D digital noise reduction (DNR), self-adaptive shutter, built-in spotlight, customisable motion zones, strobe light alarm, heart beat, smart human motion detection
Environmental Parameters (operating)
-20 °C - 50 °C; 95% (non-condensing) relative humidity
Audio Support
Wireless
18.3 cm
11.6 cm
16.6 cm
835 g
Camera
Colour - Day&Night - pan / tilt - outdoor - weatherproof
Digital Video Format
H.264, H.265
Max Digital Video Resolution
2304 x 1296
Motion Detection
Video Modes
2K
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
2304 x 1296
Frame Rate (max)
Image Sensor
3 MP PS CMOS 1/2.8"
Lens Construction
Horizontal Field of View (degree)
83
Vertical Field of View (degree)
44
Diagonal Field of View (degree)
100
Panning
Range (degree)
340
Tilting
Range (degree)
65
Network Interface
LTE
Network Protocols
TLS
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Encryption Algorithm
128-bit AES
Screw kit, drill hole template, SIM card adapter
1 x USB-C cable - external
RoHS, WEEE, REACH, IP65, UKCA
Power Requirements
DC 5 V - 2 A
10400 mAh
Internet of Things (IoT)
Shipping Width
21.6 cm
Shipping Depth
14.5 cm
Shipping Height
20.3 cm
Shipping Weight
1.072 kg
-20 °C
50 °C
Relative Humidity (operating)
Brand: Ezviz
Stock Status: While stocks last
Stock Status: Clearance
