GeForce GTX TITAN X
The EVGA GeForce GTX TITAN X combines the technologies and performance of the new NVIDIA Maxwell architecture in the fastest and most advanced graphics card on the planet.
This incredible GPU delivers unrivaled graphics, acoustic, thermal and power-efficient performance. The most demanding enthusiast can now experience extreme resolutions up to 4K-and beyond.
Enjoy hyper-realistic, real-time lighting with advanced NVIDIA VXGI, as well as NVIDIA G-SYNC display technology for smooth, tear-free gaming. Plus, you get DSR technology that delivers a brilliant 4K experience, even on a 1080p display.
SPECIFICATIONS
Base Clock: 1000 MHZ
Boost Clock: 1075 MHz
Memory Clock: 7010 MHz Effective
CUDA Cores: 3072
Bus Type: PCI-E 3.0
Memory Detail: 12288MB GDDR5
Memory Bit Width: 384 Bit
Memory Speed: 0.28ns
Memory Bandwidth: 336.5 GB/s
DIMENSIONS
Height: 4.376in - 111.15mm
Length: 10.5in - 266.7mm
Width: Dual Slot
KEY FEATURES
NVIDIA Dynamic Super Resolution Technology
NVIDIA MFAA Technology
NVIDIA GameWorks Technology
NVIDIA GameStream Technology
NVIDIA G-SYNC Ready
Microsoft DirectX 12
NVIDIA GPU Boost 2.0
NVIDIA Adaptive Vertical Sync
NVIDIA Surround Technology
NVIDIA SLI Ready
NVIDIA CUDA Technology
OpenGL 4.4 Support
OpenCL Support
HDMI 2.0, DisplayPort 1.2 and Dual-link DVI
PCI Express 3.0
RESOLUTION & REFRESH
Max Monitors Supported: 4
240Hz Max Refresh Rate
Max Analog: 2048x1536
Max Digital: 4096x2160
REQUIREMENTS
500 Watt or greater power supply.(1)
PCI Express, PCI Express 2.0 or PCI Express 3.0 compliant motherboard with one graphics slot.
An available 6-pin PCI-E power connector and an available 8 pin PCI-E power connector
Windows 8 32/64bit, Windows 7 32/64bit, Windows Vista 32/64bit
(1)Minimum sy stem power requirement based on a PC conf igured with an Intel Core i7 3.2GHz processor.
PRODUCT WARRANTY
This product is covered under EVGA's 3 year warranty which covers parts and labor. Further warranty extension is available upon registration within 90 days of purchase. For more details please visit www.evga.com/warranty
This innovative feature can deliver 4K fidelity to 1080P displays for exceptional detail and image quality. -
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. Add in a fourth accessory display to get access to your email, web, or other applications whle you game. -
MFAA delivers a 30% performance boost while maintaining smooth, high-quality edges by alternating sample calculations across each frame and each pixel. -
NVIDIA SLI Ready
NVIDIA SLI technology offers amazing performance scaling by implementing AFR (Alternate Frame Rendering) for the world's premier gaming solution with solid, state-of-the-art drivers. -
NVIDIA GameWorks pushes the limits fo gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games. -
Unlock the power of the GPU's processor cores to accelerate demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs. -
Stream extreme GeForce GTX PC gaming experiences to portable device like NVIDIA SHIELD with super-smooth, low-latency performance. -
NVIDIA G-SYNC Ready
NVIDIA G-SYNC monitors feature revolutionary NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is the smoothest, fastest, and most responsive gaming experience ever seen. -
Dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. This allows gamers to push performance to new levels. -
PCI Express 3.0
This card is designed for the PCI Express 3.0 bus architecture, offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications. It also maintains backwards compatibility with existing PCI Express motherboards for the broadest support. -
Dynamically enable vertical sync based on your current frame rates for the smoothest gaming experience.
- EVGA GeForce GTX TITAN X - graphics card - GF GTX TITAN X - 12 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX TITAN X
- Memory
- 12 GB GDDR5
- Core Clock
- 1000 MHz
- Boost Clock
- 1075 MHz
- CUDA Cores
- 3072
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , 3 x DisplayPort , HDMI
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 26.67 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1000 MHz
- Boost Clock
- 1075 MHz
- CUDA Cores
- 3072
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Nvidia CUDA technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks
- Size
- 12 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 384-bit
- Bandwidth
- 336.5 GBps
- OS Required
- Microsoft Windows Vista / 7 / 8, Microsoft Windows Vista / 7 / 8 (64-bit versions)
- Required Power Supply
- 600 W
- Additional Requirements
- 6 pin PCI Express power connector, 8 pin PCI Express power connector
- 26.67 cm
- 11.115 cm
- Limited warranty - 3 years
