The new EVGA GeForce GTX 980 is powered by the next-generation NVIDIA Maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next-generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPUs can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology. Scenes are significantly more lifelike as light interacts more realistically in the game environment.
EVGA ACX 2.0
This card features EVGA ACX 2.0 cooling. With optimized Swept fan blades, double ball bearings and an extreme low power motor, EVGA ACX 2.0 delivers more air flow with less power, unlocking additional power for the GPU.
Dynamic Super Resolution Technology
Enable the detail of 4K monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
Super-Smooth and Stutter-Free
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology, including 4K. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Performance
- NVIDIA GTX 980
- 2048 CUDA Cores
- 1266 MHz Base Clock
- 1367 MHz Boost Clock
- 162GT/s Texture Fill Rate
- 4096 MB, 256 bit GDDR5
- 7010 MHz (effective)
- 224.3 GB/s Memory Bandwidth
- PCI-E 3.0 16x
- DVI-I, DisplayPort, DisplayPort, DisplayPort, HDMI
Resolution & Refresh
- Max Monitors Supported: 4
- 240Hz Max Refresh Rate
- Max Analog : 2048x1536
- Max Digital : 4096x2160
Dimensions
- Height: 4.376in - 111.15mm
- Length: 10.5in - 266.7mm
- Width: Dual Slot
Operating System Support
- Windows 8 32/64bit
- Windows 7 32/64bit
- Windows Vista 32/64bit
Requirements
- Minimum of a 500 Watt power supply.
- Two available 6-pin PCI-E power connectors
- Total Power Draw : 165 Watts
Incredible speed and power efficiency
The GTX 980 is very fast and offers the most advanced performance in its class. It delivers 2x the performance of previous-generation cards, bringing more gaming experiences to virtual reality, HD, and ultra-resolution 4K displays. -
Dynamic super resolution technology
Enable the detail of 4K monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering. -
Super-smooth and stutter-free
GeForce GTX 980 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology, including 4K. Together, these technologies provide the most immersive and competitive gaming experiences possible. -
This innovative feature can deliver 4K fidelity to 1080P displays for exceptional detail and image quality. -
MFAA technology
MFAA delivers a 30% performance boost while maintaining smooth, high-quality edges by alternating sample calculations across each frame and each pixel. -
GameWorks technology
NVIDIA GameWorks pushes the limits of gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games. -
GameStream technology
Stream extreme GeForce GTX PC gaming experiences to portable device like NVIDIA SHIELD with super-smooth, low-latency performance. -
GPU Boost
Dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. This allows gamers to push performance to new levels. -
Adaptive vertical sync
Dynamically enable vertical sync based on your current frame rates for the smoothest gaming experience. -
Surround technology
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. Add in a fourth accessory display to get access to your email, web, or other applications while you game. -
SLI ready
Industry leading NVIDIA SLI technology offers amazing performance scaling by implementing AFR for the world's premier gaming solution with solid, state-of-the-art drivers. -
CUDA technology
Unlock the power of the GPU's processor cores to accelerate demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
- EVGA GeForce GTX 980 - Superclocked ACX 2.0 - graphics card - GF GTX 980 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980
- Memory
- 4 GB GDDR5
- Core Clock
- 1266 MHz
- Boost Clock
- 1367 MHz
- CUDA Cores
- 2048
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- 4
- DVI-I , 3 x DisplayPort , HDMI
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 26.67 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1266 MHz
- Boost Clock
- 1367 MHz
- CUDA Cores
- 2048
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Nvidia CUDA technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks, eVGA Active Cooling Xtreme (ACX) 2.0
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 256-bit
- Bandwidth
- 224.3 GBps
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- Required Power Supply
- 500 W
- Additional Requirements
- Adjacent PCI slot, two 6-pin power connectors
- 165 Watt
- Software Included
- EVGA Precision X, EVGA OC Scanner X
- 26.67 cm
- 11.115 cm
- Limited warranty - 3 years
