EVGA GeForce GTX 970 Superclocked ACX 2.0 Gaming 4GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: 9WGMWS00 Mfr#: 04G-P4-2974-KR
  • NVIDIA GeForce GTX 970
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
The EVGA GeForce GTX 970 is powered by NVIDIA Maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features. Maxwell is the highly advanced GPU architecture ever made, designed to be the engine of perfect gaming. Inspired by light, it was designed to solve extremely complex lighting and graphics challenges in visual computing. Gaming GPUs can dynamically render indirect light using the VXGI technology. Scenes are significantly more lifelike as light interacts more realistically in the game environment.
EVGA ACX 2.0
This card features EVGA ACX 2.0 cooling. With optimized Swept fan blades, double ball bearings and an extreme low power motor, EVGA ACX 2.0 delivers more air flow with less power, unlocking additional power for the GPU.
Dynamic Super Resolution Technology
Enable the detail of 4K monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
Super-Smooth and Stutter-Free
GeForce GTX 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology, including 4K. Together, these technologies provide the most immersive and competitive gaming experiences possible.
  • NVIDIA Dynamic Super Resolution technology
    This innovative feature can deliver 4K fidelity to 1080p displays for exceptional detail and image quality.
  • NVIDIA SLI ready
    Industry leading NVIDIA SLI technology offers amazing performance scaling by implementing AFR (Alternate Frame Rendering) for the world's premier gaming solution with solid, state-of-the-art drivers.
  • NVIDIA MFAA technology
    MFAA delivers more performance boost while maintaining smooth, high-quality edges by alternativing sample calculations across each frame and each pixel.
  • NVIDIA CUDA technology
    Unlock the power of the GPU's processor cores to accelerate demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs.
  • NVIDIA GameWorks technology
    NVIDIA GameWorks pushes the limits fo gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games.
  • OpenGL 4.4 support
    Supporting the latest standards in the OpenGL API.
  • NVIDIA GameStream technology
    Stream extreme GeForce GTX PC gaming experiences to portable device like NVIDIA SHIELD with super-smooth, low-latency performance.
  • OpenCL support
    Supporting the latest standards in GPGPU computing.
  • NVIDIA G-SYNC ready
    NVIDIA G-SYNC monitors feature rebvolutionary NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is the smoothest, fastest, and most responsive gaming experience ever seen.
  • HDMI 2.0, DisplayPort 1.2 and Dual-link DVI
    Supporting up to four concurrent monitors.
  • Microsoft DirectX 12
    Support for the latest Microsoft DirectX API to enable next-generation gaming.
  • PCI Express 3.0
    This card is designed for the PCI Express 3.0 bus architecture, offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications. It also maintains backwards compatibility with existing PCI Express motherboards for the broadest support.
  • NVIDIA GPU Boost 2.0
    Dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. This allows gamers to push performance to high levels.
  • EVGA ACX 2.0 cooling
  • NVIDIA Adaptive Vertical Sync
    Dynamically enable vertical sync based on your current frame rates for the smoothest gaming experience.
  • Triple BIOS ready
    Three seperate BIOS's that you can switch with the flick of a switch.
  • NVIDIA Surround technology
    With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. Add in a fourth accessory display to get access to your email, web, or other applications whle you game.
EVGA GeForce GTX 970 - Superclocked ACX 2.0 - graphics card - GF GTX 970 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1165 MHz
Boost Clock
1317 MHz
CUDA Cores
1664
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenCL, OpenGL 4.4, DirectX 12
24.13 cm x 11.115 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1165 MHz
Boost Clock
1317 MHz
CUDA Cores
1664
Max Resolution
4096 x 2160 at 240 Hz
4
API Supported
Nvidia CUDA technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks, eVGA Active Cooling Xtreme (ACX) 2.0, Voxel Global Illumination Technology (VXGI)
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Bandwidth
224.3 GBps
Microsoft Windows Vista / 7 / 8
Required Power Supply
500 W
Additional Requirements
2 x 6 pin PCI Express power connector
145 Watt
Software Included
Drivers & Utilities
24.13 cm
11.115 cm
Limited warranty - 3 years
