The EVGA GeForce GTX 970 is powered by NVIDIA Maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features. Maxwell is the highly advanced GPU architecture ever made, designed to be the engine of perfect gaming. Inspired by light, it was designed to solve extremely complex lighting and graphics challenges in visual computing. Gaming GPUs can dynamically render indirect light using the VXGI technology. Scenes are significantly more lifelike as light interacts more realistically in the game environment.
EVGA ACX 2.0
This card features EVGA ACX 2.0 cooling. With optimized Swept fan blades, double ball bearings and an extreme low power motor, EVGA ACX 2.0 delivers more air flow with less power, unlocking additional power for the GPU.
Dynamic Super Resolution Technology
Enable the detail of 4K monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
Super-Smooth and Stutter-Free
GeForce GTX 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology, including 4K. Together, these technologies provide the most immersive and competitive gaming experiences possible.
NVIDIA Dynamic Super Resolution technology
This innovative feature can deliver 4K fidelity to 1080p displays for exceptional detail and image quality. -
NVIDIA SLI ready
Industry leading NVIDIA SLI technology offers amazing performance scaling by implementing AFR (Alternate Frame Rendering) for the world's premier gaming solution with solid, state-of-the-art drivers. -
NVIDIA MFAA technology
MFAA delivers more performance boost while maintaining smooth, high-quality edges by alternativing sample calculations across each frame and each pixel. -
NVIDIA CUDA technology
Unlock the power of the GPU's processor cores to accelerate demanding tasks such as video transcoding, physics simulation, ray tracing, and more, delivering incredible performance improvements over traditional CPUs. -
NVIDIA GameWorks technology
NVIDIA GameWorks pushes the limits fo gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games. -
OpenGL 4.4 support
Supporting the latest standards in the OpenGL API. -
NVIDIA GameStream technology
Stream extreme GeForce GTX PC gaming experiences to portable device like NVIDIA SHIELD with super-smooth, low-latency performance. -
OpenCL support
Supporting the latest standards in GPGPU computing. -
NVIDIA G-SYNC ready
NVIDIA G-SYNC monitors feature rebvolutionary NVIDIA technology that eliminates screen tearing while also reducing input lag. The result is the smoothest, fastest, and most responsive gaming experience ever seen. -
HDMI 2.0, DisplayPort 1.2 and Dual-link DVI
Supporting up to four concurrent monitors. -
Microsoft DirectX 12
Support for the latest Microsoft DirectX API to enable next-generation gaming. -
PCI Express 3.0
This card is designed for the PCI Express 3.0 bus architecture, offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications. It also maintains backwards compatibility with existing PCI Express motherboards for the broadest support. -
NVIDIA GPU Boost 2.0
Dynamically maximizes clock speeds based on workload and allows enthusiast-class controls such as temperature target and fan controls, extra over-voltage headroom, and optimizations for water-cooling solutions. This allows gamers to push performance to high levels. -
With optimized Swept fan blades, double ball bearings and an extreme low power motor, EVGA ACX 2.0 delivers more air flow with less power, unlocking additional power for the GPU. -
NVIDIA Adaptive Vertical Sync
Dynamically enable vertical sync based on your current frame rates for the smoothest gaming experience. -
Triple BIOS ready
Three seperate BIOS's that you can switch with the flick of a switch. -
NVIDIA Surround technology
With a single card you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game" experience. Add in a fourth accessory display to get access to your email, web, or other applications whle you game.
- EVGA GeForce GTX 970 - Superclocked ACX 2.0 - graphics card - GF GTX 970 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 970
- Memory
- 4 GB GDDR5
- Core Clock
- 1165 MHz
- Boost Clock
- 1317 MHz
- CUDA Cores
- 1664
- Effective Memory Clock
- 7.01 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
- API Supported
- OpenCL, OpenGL 4.4, DirectX 12
- 24.13 cm x 11.115 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1165 MHz
- Boost Clock
- 1317 MHz
- CUDA Cores
- 1664
- Max Resolution
- 4096 x 2160 at 240 Hz
- 4
- API Supported
- Nvidia CUDA technology, Nvidia Surround technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA Dynamic Super Resolution technology, NVIDIA MFAA technology, NVIDIA GameWorks, eVGA Active Cooling Xtreme (ACX) 2.0, Voxel Global Illumination Technology (VXGI)
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.01 GHz
- Bus Width
- 256-bit
- Bandwidth
- 224.3 GBps
- OS Required
- Microsoft Windows Vista / 7 / 8
- Required Power Supply
- 500 W
- Additional Requirements
- 2 x 6 pin PCI Express power connector
- 145 Watt
- Software Included
- Drivers & Utilities
- 24.13 cm
- 11.115 cm
- Limited warranty - 3 years
