Get the weapon of choice for gamers - the EVGA GeForce GTX 660 Ti. It adds a new dimension to the Nvidia Kepler-powered family of graphics cards by delivering the ideal fusion of power, performance and affordability. Experience faster, smoother, richer gaming with innovative Nvidia technologies like TXAA antialiasing, Adaptive Vertical Sync, and PhysX.
No 1 American Nvidia Brand, EVGA warranty allows for overclocking, the consumer can replace the reference cooler for better overclocking and as long as they return the original cooler with the card then it will be covered by the EVGA warranty. There is Direct RMA with a 7 working day turn around, Step-up programme enables consumers to upgrade their graphics card within 3 months of purchase and only pay the difference for the more expensive card. EVGA forum offers advice, driver updates and special offers and the EVGA GPU purchase gives enthusiasts free online gaming with EVGA gaming servers.
Nvidia SMX Engine
Nvidia GPU Boost
- Nvidia Adaptive Vertical Sync
- Nvidia Surround Technology
Support for four concurrent displays; two dual-link DVI connectors, HDMI and Displayport 1.2 - Microsoft DirectX 11
Nvidia PhysX Technology
- Nvidia 3D Vision-Ready
- Nvidia SLI-Ready
- Nvidia CUDA Technology
- PCI Express 3.0 Support
- OpenGL 4.2 Support
- 3 Year Manufacturers Warranty (extended to 10 Years if card is registered with EVGA within 30 days of purchase)
Base Clock: 980 MHz
Boost Clock: 1059 MHz
- Memory Clock: 6008 MHz Effective
- CUDA Cores: 1344
- Bus Type: PCI-E 3.0
- Memory Detail: 3072MB GDDR5
- Memory Bit Width: 192 Bit
- Memory Speed: 0.33ns
- Memory Bandwidth: 144.19 GB/s
- Texture Fill Rate: 109.8 GT/s
Kepler GPU architecture
NVIDIA's Kepler GPU architecture has been designed from the ground up not just for maximum performance in the latest DirectX 11 games, but optimal performance per watt. The SMX streaming multiprocessor is twice as efficient as the prior generation and the geometry engine draws triangles twice as fast. The result is world class performance and the highest image quality in an elegant and power efficient graphics card. -
NVIDIA GPU boost
Up until now, GPUs have operated at a fixed clock speed when playing 3D games, even if they have the potential to run faster. GPU boost intelligently monitors graphics work load and increases the clock speed whenever possible. The result is that the GPU always performs at its peak and you get the highest framerate possible. -
NVIDIA adaptive vertical sync
Nothing is more distracting than framerate stuttering and screen tearing. The first tends to occur when framerates are low, the second when framerates are high. Adaptive V-sync is a smarter way to render frames. At high framerates, V-sync is enabled to eliminate tearing, at low frame rates, it's disabled to minimize stuttering. It gets rid of distractions so you can get on with gaming. -
NVIDIA surround with up to four monitors
Nothing is as breathtaking as playing your favorite games across three monitors. At 5760 x 1080, the expanded field of view fully engages human peripheral vision and provides for the most immersive experience in racing and flight simulators. Add in a fourth display to keep tabs on chat, email or web while you are gaming. -
TXAA anti-aliasing
Anti-aliasing helps to smooth out jagged lines in games. Existing techniques like MSAA are effective at removing jagged lines in still images but struggle with crawling and shimmering artifacts when the player is in motion. TXAA is an anti-aliasing mode that combines MSAA, temporal filtering, and post processing for the highest edge quality and minimal shimmering during gameplay.
- EVGA GeForce GTX 660 Ti Superclocked+ - graphics card - GF GTX 660 Ti - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 660 Ti
- Memory
- 3 GB GDDR5
- Core Clock
- 980 MHz
- Boost Clock
- 1059 MHz
- CUDA Cores
- 1344
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
- Max Monitors Supported
- 4
- DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter , DVI-D (dual link)
- API Supported
- DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2
- 24.1 cm x 11.115 cm
- 3-year warranty
- Bundled with
- EVGA Backplate
- Graphics card
- Bundled with
- EVGA Backplate
- Bus Type
- Graphics Engine
- Core Clock
- 980 MHz
- Boost Clock
- 1059 MHz
- CUDA Cores
- 1344
- Max Resolution
- 2560 x 1600
- 4
- API Supported
- Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, Deep Color technology, Blu-Ray 3D Support, TXAA, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 192-bit
- Bandwidth
- 144.19 GBps
- OS Required
- Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions)
- Required Power Supply
- 450 W
- Additional Requirements
- Adjacent PCI slot, two 6-pin power connectors
- Included Accessories
- 2 x 4 pin to 6 pin power cables
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
- 24.1 cm
- 11.115 cm
- 1.36 kg
- Limited warranty - 3 years
