- EVGA GeForce GT 620 - graphics card - GF GT 620 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 620
- Memory
- 1 GB DDR3
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Effective Memory Clock
- 1.4 GHz
- Shader Clock
- 1400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- 2 x DVI-I (dual link) , Mini-HDMI
- API Supported
- DirectX 11, OpenGL 4.2
- 14.48 cm x 11.12 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Shader Clock
- 1400 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- Nvidia CUDA technology, Nvidia PhysX-Ready
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.4 GHz
- Bus Width
- 64-bit
- Bandwidth
- 11.2 GBps
- OS Required
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Required Power Supply
- 350 W
- Additional Requirements
- Adjacent PCI slot
- Software Included
- Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X
- 14.48 cm
- 11.12 cm
- 907 g
- Limited warranty - 3 years
