EVGA GeForce GT 210 520MHz 1GB PCI-Express 2.0 HDMI
Quicklinx: 877GWS00 Mfr#: 01G-P3-1313-KR
  • High-Definition Multimedia Interface (HDMI)
Good graphics processing is a required ingredient in the modern PC. With DirectX 10.1 support, Nvidia PhysX technology, HDMI output and Nvidia CUDA technology the EVGA GeForce 210 is an essential addition to your PC. Whether you are doing video or photo editing, gaming, HD video playback, or just looking for a Premium Windows 7 experience, the EVGA GeForce 210 brings incredible processing power, at an incredible price.
No 1 American Nvidia Brand, EVGA warranty allows for overclocking, the consumer can replace the reference cooler for better overclocking and as long as they return the original cooler with the card then it will be covered by the EVGA warranty. There is Direct RMA with a 7 working day turn around, Step-up programme enables consumers to upgrade their graphics card within 3 months of purchase and only pay the difference for the more expensive card. EVGA forum offers advice, driver updates and special offers and the EVGA GPU purchase gives enthusiasts free online gaming with EVGA gaming servers.
  • Microsoft DirectX 10.1 Shader Model 4.1 Support
  • Nvidia PureVideo HD Technology
  • PCI Express 2.0 Support
  • OpenGL Support
  • Dual-Link HDCP Capable
  • Nvidia CUDA Technology
  • Microsoft Windows XP/Vista/7 Support
  • Nvidia PhysX Ready Technology
  • OpenCL Support
  • 3 Year Manufacturers Warranty
Spec
  • Core Clock: 520 MHz
  • Memory Clock: 1200 MHz Effective
  • Shader Clock: 1238 MHz
  • CUDA Cores: 16
  • Bus Type: PCI-E 2.0
  • Memory Detail: 1024MB DDR3
  • Memory Bit Width: 64 Bit
  • Memory Bandwidth: 9.6 GB/s
  • (1) DVI, (1) HDMI and (1) VGA Connector
  • Warranty: 3 Year Manufacturers Warranty
  • DVI-I output
    Digital video interface - integrated - supports both VGA and digital signals.
  • Second generation Unified Shader Architecture
    The Unified Shader Architecture technology offers 50% more performance through 240 enhanced processing cores.
  • NVIDIA CUDA support
    Accelerates CUDA based applications through the GPU's processing power allowing for faster application performance such as video transcoding.
  • NVIDIA PhysX ready
    Enjoy more visual immersion with life like physics for a more dynamic experience.
  • NVIDIA PureVideo HD technology
    Smooth video, accurate colors, precise image scaling, video decode acceleration and post processing, all provided by the graphics card to give you the best HD experience possible.
EVGA GeForce 210 - graphics card - GF 210 - 1 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce 210
1 GB DDR3
Core Clock
520 MHz
Effective Memory Clock
1.2 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
DVI-I (dual link) , HDMI , VGA
API Supported
OpenGL 3.1, OpenCL, DirectX 10.1
16.8 cm x 6.9 cm
3-year warranty
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce 210
Core Clock
520 MHz
RAMDAC
400 MHz
Max Resolution
2560 x 1600 at 240 Hz
API Supported
Fanless heatsink, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
Required Power Supply
300 W
Software Included
Drivers & Utilities
16.8 cm
6.9 cm
Limited warranty - 3 years
