The EVGA SuperNOVA 1000 G2 has arrived! This power supply is 80 PLUS Gold rated, offers 1000 W of continuous power, exceptional efficiency and is fully modular. Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G2 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G2!
- EVGA SuperNOVA 1000 G2 - power supply - 1000 Watt
- Power supply - internal
- Specification Compliance
- ATX
- 80 PLUS Certification
- 80 PLUS Gold
- 3 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- +5V - 20 A , +3.3V - 20 A , +12V - 83.3 A , -12V - 0.5 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin main output , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 10 x 15 pin Serial ATA power , 5 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- 15 cm x 20 cm x 8.5 cm
- 10-year warranty with product registration
- ATX
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- Efficiency
- 90% (115VAC) / 92% (220-240VAC)
- 80 PLUS Gold
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, cable management, short-circuit protection, single 12V rail
- TUV, C-Tick, BSMI, CB, CCC, FCC, RoHS, cTUVus
- Limited warranty - 10 years
- 0 °C
- 50 °C
- 15 cm
- 20 cm
- 8.5 cm
- 3 kg
