Affordable, height-adjustable dual-monitor stand for maximum productivity and comfort. Save time by using multiple applications at once - eliminate toggling back and forth between documents and programs. Simultaneously lift LCD screens to proper height for unsurpassed ergonomic comfort.
- Ergotron Neo-Flex Dual LCD Lift Stand stand - for 2 LCD displays - black
- Product Type
- Stand
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- Up to 22"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 15.4 kg
- Black
- 3-year warranty
- Black
AV Furniture
- Stand
- Recommended Use
- 2 LCD displays
- Up to 22"
- Max Load Weight
- 15.4 kg
- Adjustable height
- Limited warranty - 3 years
