Epson Workforce WF-3540DTWF - WiFi - 4-in-1
Quicklinx: 8GDFWS00 Mfr#: C11CC31301
Robust and flexible
Thanks to Epson's fast drying DURABrite Ultra Ink, prints are water, smudge and highlighter resistant. Cartridges are available in XL size, helping to save further on costs. XL inks are ideal for high print volumes, offering up to a 50 percent lower cost-per-page than competitive lasers(1).
Business-quality printing at up to 15ppm for single-sided documents and 7.9ppm for double-sided documents(2), ensure work is delivered quickly and efficiently.
Up to 500 sheets of A4 plain paper can be loaded via dual 250-sheet trays, and a single-sheet rear-feed paper path accepts various medias such as card, envelopes and business cards. With a duplex ADF for multi-page scanning, copying and faxing this printer provides everything a small office or workgroup needs.
Epson Connect(3) allows users to print wirelessly from smartphones and tablet PCs within the office and from anywhere in the world by emailing documents directly to the printer's email address. The Remote Printer Driver offers more flexibility to print from a PC to any Epson Connect printer anywhere in the world, while Scan-to-Cloud enables users to store scanned documents directly in Cloud services. Both Apple AirPrint and Google Cloud print are also supported.
This device also has Wi-Fi Direct, allowing it to connect directly to other Wi-Fi Direct capable devices without the need for a wireless access point such as a router.
Wi-Fi 4-in-1
Print, scan, copy and fax with ADF
Fast print speeds
Print at up to 15 pages per minute(2)
Flexible connectivity
Wi-Fi, Wi-Fi Direct and Ethernet
Dual paper trays
Two 250-sheet capacity trays
Epson Connect
Freedom to print and scan anywhere
  1. For more information, please visit www.epson.eu/inkjetsaving
  2. Determined in accordance with ISO/IEC 24734 showing the average of ESAT from the Office Category Test for default simplex and duplex. For more information, please visit www.epson.eu/testing
  3. Requires a wireless connection to the internet. For more information, supported languages and devices please visit www.epsonconnect.eu
  4. For more information, please visit www.epson.eu/testing
  5. The maximum number of printed pages per month based on the performance capabilities of the printer, including ISO rated print speeds and paper handling capabilities
  6. Adaptor required (not supplied in box)
  • Efficient connectivity
    With a variety of interfaces including LAN, USB 2.0, USB host, and Wi-Fi(n), alongside AirPrint and Google Cloud Print mobile printing capabilities, this device ensures seamless connection across multiple platforms.
  • High-quality printing
    Boasts a maximum resolution of 5760 x 1440 DPI for both black and color prints, supported by Epson DURABrite Ultra inks for professional-quality documents and vibrant photos.
  • Versatile media handling
    Accommodates a wide range of media sizes and types, including envelopes and plain paper, with a generous 500-sheet standard media capacity, making it suitable for various printing needs.
  • Advanced scanning
    Features an optical resolution of 1200 x 2400 DPI with automatic duplexing, allowing for high-quality scans of documents and photos.
  • Eco-friendly design
    ENERGY STAR certified, ensuring efficient power consumption with a maximum operational power of 17 W and a sleep mode power consumption of just 2 W, contributing to energy savings.
Epson WorkForce WF-3540DTWF - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
12000 impressions
Max Printing Speed
Up to 15 ppm (mono) / up to 9.2 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
500 sheets
Max Media Capacity
500 sheets
Bypass Feeder Capacity
1 sheet
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card
AC 230 V (50/60Hz)
44.9 cm x 42.7 cm x 30.8 cm
10.9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
12000 impressions
AirPrint Enabled
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card
Copying
Automatic Duplexing
Printing
Nozzle Configuration
384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2 pl
Ink Type
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Automatic redialing, colour faxing
Document & Media Handling
Max Original Size
Original Type
Sheets
30 sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
500 sheets
Max Media Capacity
500 sheets
1 sheet
2 x input tray - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 1 sheet , ADF - 30 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 95 g/m²
Speed Details
Printing: up to 38 ppm - B/W , Printing: up to 38 ppm - colour , Printing: up to 15 ppm - B/W (ISO/IEC 24734) , Printing: up to 9.2 ppm - colour (ISO/IEC 24734) , Printing: up to 7.9 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 5.7 ppm (A4) - colour duplex (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.5.8 or later
Software Included
Epson Event Manager, Epson Easy Photo Print, Epson Fax Utility, Presto! PageManager 9
AC 230 V (50/60Hz)
17 Watt
Power Consumption Standby
6.2 Watt
Power Consumption Sleep
2 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60950-1, TBR21, EN 300 328, EN 301 489-1, EN 301 489-17
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
44.9 cm
42.7 cm
30.8 cm
10.9 kg
Shipping Width
53.6 cm
Shipping Depth
51.4 cm
Shipping Height
39.6 cm
Shipping Weight
13.7 kg
Sound Emission
37 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
8GDF Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.29
8GDF Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.72
8GDF Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.79
