Your basket is empty
Epson WorkForce Pro WF-5620DWF Colour A4 Multifunction Printer
£80 Cashback Available or Free 3 Year Warranty Upgrade!
Quicklinx: 9C2BWS00 Mfr#: C11CD08301BY
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
25 in stock
£159.21 ex VAT
£191.05 inc VAT
Express delivery Order within the next 11 hours for delivery tomorrow
Low running costs
The multifunction WorkForce Pro WF-5620DWF has an up to 50 percent lower cost per page than competitive colour lasers, saving you money as you take advantage of this printer's high capacity ink cartridges of up to 4,000 pages². And there are fewer parts to replace than a laser.
Ecological
The WF-5620DWF uses up to 80 percent less power than competitive colour lasersthanks, in part, to its no heat technology. No ozone gases are emitted, and an improved quiet print mode and no fan noise during or after printing makes it ideal for the work environment.
Save time
This efficient business printer is faster than a laser on typical print jobs¹, with print speeds of up to 34ppm in mono and 30ppm in colour, or 20ppm ISO print speed in both³. Its high paper capacity of 580 sheets means less time is spent refilling, and it has a high monthly duty cycle of up to 35,000 pages4.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Scan-to functions and LDAP support help this printer easily integrate into the business environment. Its intuitive colour touch-screen makes functions readily available, and the rear manual paper tray lets you print on a range of media.
Epson WorkForce Pro WF-5620DWF - multifunction printer (colour)
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Monthly Duty Cycle (max)
35000 pages
Max Copying Speed
Up to 19 ppm (mono) / up to 19 ppm (colour)
Max Copying Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Printing Speed
Up to 34 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
330 sheets
Max Media Capacity
580 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud
AC 230 V
46.1 cm x 44.2 cm x 34.2 cm
14.2 kg
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
35000 pages
Display Features
Touch screen
PC Connection
AirPrint Enabled
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
2.8 pl
Printer Drivers / Emulations
Windows GDI driver, EPSON ESC/P Raster
Ink Type
Epson DURABrite Ultra inks
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 550 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Automatic redialing
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
330 sheets
Max Media Capacity
580 sheets
80 sheets
150 sheets
Input tray - 250 sheets , Bypass tray - 80 sheets , Output tray - 150 sheets , ADF - 35 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 20 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 20 ppm (A4) - color (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 19 ppm - B/W (ISO/IEC 24735) , Copying: up to 19 ppm - colour (ISO/IEC 24735) , Scanning: up to 6.3 spm - B/W , Scanning: up to 4.5 spm - colour
1 x USB 2.0 - 9 pin USB Type B , 1 x USB host - 9 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, WEP, IPsec, 802.1x, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later
Software Included
Drivers & Utilities
AC 230 V
20 Watt
Power Consumption Standby
7.8 Watt
Power Consumption Sleep
1.8 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
Limited warranty - 1 year
46.1 cm
44.2 cm
34.2 cm
14.2 kg
Sound Emission
52 dBA (operating)
9C2B C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.31
9C2B C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.25
9C2B C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.62
9C2B C2G 2m Cat6a Shielded Patch - Blue In Stock £7.60
9C2B C2G TruLink Media Gateway RJ45 Cap In Stock £0.59
9C2B C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.62
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Brand: Epson
Price Range Ex VAT: 150 - 300
