Save time and money
It offers up to a 50 percent lower cost per page compared to competitive colour lasers, and saves you time, being faster than a laser on typical print jobs , with no warm-up period. The WF-4630DWF uses up to 80 percent less power than competitive colour lasers .
High performance
Its high-yield cartridges are low maintenance and its 20ppm print speed in black and colour means you can print quickly with a print resolution of up to 4800x1200dpi. The paper capacity of up to 330 sheets means you won't need to spend time refilling.
Built for business
This inkjet printer has a monthly duty cycle of 30,000 pages4. Prints dry fast thanks to the DURABrite Ultra ink, meaning faster print speeds when printing double sided.
Flexible and easy to use
Its intuitive touch-screen makes functions readily available, and the rear manual paper tray lets you print on a range of media. It supports Epson Connect5, so you can easily print from smartphones, tablets and more. Its Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router. Document Capture Pro compatibility offers seamless integration into most document management systems.
PrecisionCore
PrecisionCore, Epson's most advanced printhead technology, powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing.
Save time and money
It offers up to a 50 percent lower cost per pagecompared to competitive colour lasers, and saves you time, being faster than a laser on typical print jobs, with no warm-up period. The WF-4630DWF uses up to 80 percent less power than competitive colour lasers. -
High performance
Its high-yield cartridges are low maintenance and its 20ppm print speed in black and colour means you can print quickly with a print resolution of up to 4800x1200dpi. The paper capacity of up to 330 sheets means you won't need to spend time refilling. -
Built for business
This inkjet printer has a monthly duty cycle of 30,000 pages. Prints dry fast thanks to the DURABrite Ultra ink, meaning faster print speeds when printing double sided. -
Its intuitive touch-screen makes functions readily available, and the rear manual paper tray lets you print on a range of media. It supports Epson Connect, so you can easily print from smartphones, tablets and more. Its Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router. Document Capture Pro compatibility offers seamless integration into most document management systems. -
PrecisionCore
- Epson WorkForce Pro WF-4630DWF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Max Printing Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 330 sheets
- Max Media Capacity
- 330 sheets
- Bypass Feeder Capacity
- 80 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to Cloud
- Power
- AC 110/230 V (50/60Hz)
- 46.1 cm x 42.2 cm x 34.2 cm
- 14.2 kg
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Scan to Cloud
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- Fit to page
Printing
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 2.8 pl
- Printer Drivers / Emulations
- EPSON ESC/P Raster
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Automatic redialing, colour faxing
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 330 sheets
- 330 sheets
- 80 sheets
- Input tray - 250 sheets , Bypass tray - 80 sheets , ADF - 35 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 30 ppm - colour , Printing: up to 20 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - colour duplex (ISO/IEC 24734)
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- WEP, WPA-PSK, TKIP, AES
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.6 or later
- Software Included
- Drivers & Utilities, Epson Document Capture Pro
- Voltage Required
- 20 Watt
- Power Consumption Standby
- 7.5 Watt
- Power Consumption Sleep
- 1.8 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- 46.1 cm
- 42.2 cm
- 34.2 cm
- 14.2 kg
Ink (5)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.27 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
Other bundles (1)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
