Touch-panel Small-in-One
Part of Epson's Small-in-One range, the SX445W offers cost-effective printing, scanning and copying with the flexibility of Wi-Fi connectivity, PC-free printing and smart-navigation touch-panel technology. The sleek, stylish design coupled with an ultra-compact footprint means this small-in-one effortlessly complements any home environment without taking up too much space.
Save space
The SX445W is part of the Small-in-One range - Epson's smallest all-in-ones which are 39 percent smaller than previous models. The sleek, stylish design coupled with an ultra-compact footprint means this Small-in-One effortlessly complements any home environment without taking up too much space. Additionally, this Small-in-One boasts a 25 percent reduction in packaging, which means you throw away less and helps lower your impact on the environment.
Save money
Individual DURABrite Ultra Ink cartridges save you money as you only replace the colours used. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents.
Save time
The automatic Wi-Fi set-up makes configuring laptops and computers to print wirelessly extremely easy. You don't need to know your network settings or connect with a USB cable, the SX445W automatically finds the relevant connection settings in order to configure itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home.
PC-free printing
The smart-navigation touch-panel features buttons that illuminate to easily guide users through any process. This helps eliminate any confusion and speeds up tasks. The 6.3cm colour LCD screen and accompanying memory card slot offers easy-to-use PC-free photo printing. No more waiting for computers to power up; printing directly from a memory card is straightforward and allows greater flexibility.
Mobile printing
The SX445W is also compatible with Epson iPrint which offers even more flexibility and freedom, allowing you to quickly and easily print photos and documents wirelessly from smartphones and tablet PCs.
Economical
PC-free printing
Save money with individual inks
Wi-Fi Small-in-One
Print, scan and copy wirelessly
Space-saving
Smart-navigation touch-panel
Mobile printing
Smartphone and tablet PC printing
Save space
The SX445W is part of the Small-in-One range - Epson's smallest all-in-ones which are 39 percent smaller than previous models. The sleek, stylish design coupled with an ultra-compact footprint means this Small-in-One effortlessly complements any home environment without taking up too much space. Additionally, this Small-in-One boasts a 25 percent reduction in packaging, which means you throw away less and helps lower your impact on the environment. -
Save money
Individual DURABrite Ultra Ink cartridges save you money as you only replace the colors used. DURABrite Ultra Ink is so versatile it is able to print lab-quality photos while at the same time produce crisp, clean text documents. -
Save time
The automatic Wi-Fi set-up makes configuring laptops and computers to print wirelessly extremely easy. You don't need to know your network settings or connect with a USB cable, the SX445W automatically finds the relevant connection settings in order to configure itself. Multiple users then have the freedom to print, copy and scan quickly and efficiently from anywhere in the home. -
PC-free printing
The smart-navigation touch-panel features buttons that illuminate to easily guide users through any process. This helps eliminate any confusion and speeds up tasks. The 6.3cm color LCD screen and accompanying memory card slot offers easy-to-use PC-free photo printing. No more waiting for computers to power up; printing directly from a memory card is straightforward and allows greater flexibility. -
Mobile printing
- Epson Stylus SX445W ( printer / copier / scanner ) ( colour )
- Printing Resolution
- 5,760 x 1,440 DPI
- Printing Speed
- 33 pages/min Monochrome, 15 pages/min Colour, 54 seconds/photo 10x15cm
- Paper Tray Capacity
- 100 Sheets Standard, 20 Photo Sheets
- Paper Formats
- A4, A5, A6, B5, C6 (Envelope), DL (Envelope), No. 10 (Envelope), Letter, Letter Legal, 9 x 13cm, 10 x 15cm, 13 x 18cm, 13 x 20cm, 20 x 25cm, 100 x 148mm, 16:9, User Defined
- USB 2.0 Type B, WLAN
- 4.2kg
- Warranty
- 12 months
- In the box
- Main unit, setup guide, Software (CD), Warranty document, Power Cable, Individual Ink Cartridges
- Dimensions
- 390mm x 300mm x 145mm (Width x Depth x Height)
- Performance
- Consumer
- Colours
- Black, Cyan, Yellow, Magenta
- Nozzle configuration
- Nozzles black: 128, Nozzles per colour: 42
- Minimum Droplet Size
- 3 pl
- Ink Technology
- Epson DURABrite Ultra
- All-in-One Functions
- Scan, Copy
- Scanning Resolution
- 1,200 DPI x 2,400 DPI (Horizontal x Vertical)
- LCD Display
- colour, 6.3cm
- Marginless Print, Manual Duplex
- Compatible OS
- Windows XP, XP x64, Vista, Vista x64, Windows 7, Windows 7 x64, Mac OS 10.4+, Mac OS 10.5+, Mac OS 10.6+
- WLAN Security
- WEP 64 bit, WEP 128 bit, WPA PSK (TKIP), WPA PSK (AES)
- Memory Cards
- Memory Stick, Memory Stick Pro, Memory Stick PRO-HG Duo, MagicGate Memory Stick, SD, SDHC, MMC, MMCplus, Memory Stick Duo, Memory Stick Pro Duo, Memory Stick Micro M2, MagicGate Memory Stick Duo, MiniSD, MiniSDHC, MicroSD, MicroSDHC, MMCmobile, RS-MMC, MMCmicro
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.78 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.78 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.22 |
