Precision, reliability and productivity; meeting a wide range of professional printing needs.
Professional printers designed to provide faster output without compromising on print quality.
Flawless colour
The Epson Stylus Pro 9700 flexible 44" printer gives your professional printing even more impact with thea ddition of Vivid Magenta to the Epson UltraChrome Ink set. With more accurate, longer-lasting, life-like colour it will transform the way you print POS materials, CAD/GIS prints and more.
Fast, efficient printing
The Epson Stylus Pro 9700 is packed with the latest Epson technologies that add precision, reliability and productivity to a wide range of professional printing needs. Together they give you the finest quality output without compromising speed.
Simple excellence
A range of features make the printing process as easy as possible, and gives you the flexibility to match your printer to the way you print. Fast network connection, clear, simple control and straightforward operation and maintenance are built-in.
Total control
Intelligent software helps you to get the best from your printer; whether it's keeping track of all aspects of printing, streamlining the way you work or getting creative.
Meeting demands
From business to education, our versatile printer gives you high-quality, eye-catching prints that do the job perfectly. With industry-standard quality, accuracy and durability, it combines all the features you need to transform the way your business works.
Flawless colour
Our fast, flexible 44" printer gives your professional printing even more impact with the. -
The Epson Stylus Pro 9700 is packed with the latest Epson technologies that add precision. -
Simple excellence
A range of features make the printing process as easy as possible, and gives you the flexibility to match your printer to the way you print. Fast network connection, clear, simple control and straightforward operation and maintenance are built-in. -
Total control
Intelligent software helps you to get the best from your printer; whether it's keeping track of all aspects. -
Meeting demands
- Epson Stylus Pro 9700 - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- 115 kg
- Inkjet Technology
- Epson Micro Piezo TFP
- Ink Palette Supported (Colours)
- 4-ink
- Max Media Size
- B0 plus (1118 x 1580 mm), Roll (111.8 cm)
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Interface
- USB, LAN
- Preview Screen Size
- 2.5"
- Language Simulation
- EPSON ESC/P 2, EPSON ESC/P Raster, EPSON ESC/P 3
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (32/64 bits)
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty (Poland - 2 years on-site)
- 186 cm x 66.7 cm x 121 cm
- Printer Type
Printer
- Inkjet Technology
- 4-ink
- Nozzle Configuration
- 10 x 360 nozzles
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Type
- Epson UltraChrome
- Built-in Devices
- Preview screen
- 2.5"
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 2880 x 1440 dpi
- 2880 x 1440 dpi
Media Handling
- Max Media Size
- Media Feeders
- 1 x manual - 1 roll - Roll (111.8 cm)
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 70 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- OS Required
- Limited warranty - 1 year - on-site
- Regional Warranty Exceptions
- Poland - 2 years on-site
- 10 °C
- 35 °C
- 20 - 80%
- Sound Emission (Operating)
- 50 dBA
- 186 cm
- 66.7 cm
- 121 cm
- 115 kg
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.72 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.79 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £15.14 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £20.59 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £28.08 |
