Epson Stylus Photo R3000 Colour Inkjet Printer
Epson - R3000
Quicklinx: 7JT0WS00 Mfr#: C11CA86301
Front-loading fine art paper feed
Easily insert fine art media with less risk of damage thanks to the front-loading fine art paper feed, which removes the need for space behind the printer.
Convenient high-capacity inks
Complete medium print runs and optimise your cost per page with the convenient 25.9ml high-capacity ink cartridges.
Colour LCD
View media instructions and check ink levels quickly and easily with the 2.5-inch colour LCD.
Consistent, true-to-life prints
Enjoy an improved grey balance without colour casts and a smoother, more natural-looking tonal range thanks to Epson's UltraChrome K3 Ink with Vivid Magenta and three densities of black ink. Either a standard photo or matte black is employed and switched automatically to suit the media used and, along with light black and light light black, creates true black and white images.
Choice of grey tones
Choose your own black and white tonality, from warm to neutral or cool, and customise to suit your own tastes - then easily save your settings in the print driver.
Easy-to-use print driver
Take complete control of your images with the R3000's print driver, which is incredibly easy to use. It helps you improve productivity, customise media settings and use the supplied ICC profiling to get the right output for your style.
Wide media compatibility
Print on a wide variety of media, from roll and cut-sheet fine art paper to board up to 1.3mm thick.
  • Front-loading fine art paper feed
  • Convenient high-capacity inks
  • Colour LCD
  • Consistent, true-to-life prints
  • Choice of grey tones
  • Easy-to-use print driver
  • Wide media compatibility
Epson Stylus Photo R3000 - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
15 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
8-ink
Max Media Size
A3 plus (329 x 423 mm), Roll (32.9 cm)
Min Media Size (Custom)
89 mm
Max Media Size (Custom)
329 mm
Print Speed
Up to 0.31 ppm - photo - A3 plus (329 x 423 mm)
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
Image Enhancement Technology
EPSON Advanced Variable Sized Droplet Technology (AVSDT)
USB, LAN
Media Type
Plain paper, continuous forms
Total Media Capacity
120 sheets
Media Handling
120-sheet input tray
Print server - Ethernet, Fast Ethernet
Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later, Microsoft Windows 7 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
61.6 cm x 36.9 cm x 22.8 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
8-ink
Nozzle Configuration
180 nozzles (per cartridge)
Ink Type
Epson UltraChrome K3 with Vivid Magenta
Print Speed
Wireless
USB, LAN
5760 x 1440 dpi
5760 x 1440 dpi
Media Handling
Media Handling
Media Type
Max Media Size
89 mm
329 mm
Media Sizes
Roll (32.9 cm)
120 sheets
Media Feeders
1 x automatic - 120 sheets
Print server
1 x USB 2.0 , 1 x LAN - RJ-45
Power adapter - internal
21 watt
Limited warranty - 1 year - carry-in
61.6 cm
36.9 cm
22.8 cm
15 kg
7JT0 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
7JT0 Epson STYLUS PHOTO R3000 BLACK INK In Stock £21.20
7JT0 Epson EPSON T15724010 CARTRIDGE CYAN In Stock £21.44
7JT0 Epson STYLUS PHOTO R3000 VIVID LGT MAGENTA In Stock £20.88
7JT0 Epson STYLUS PHOTO R3000 LIGHT LGT BLACK In Stock £21.44
7JT0 Epson T1575 - Print cartridge - 1 x light cyan In Stock £21.44
7JT0 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
7JT0 Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
7JT0 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.22
7JT0 Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £20.69
