Economical printing: This is a printer designed to save time and money while delivering high-quality professional results. It is affordable and cost-per-page is up to 50 percent lower than competitive laser printers1. Costs are kept low as Epson's individual ink cartridge system means only the colour used needs to be replaced, while further savings can be made thanks to a choice of different cartridge sizes including XL 'Stag' inks for high volume, low-cost printing. Automatic duplexing helps to cut paper usage by up to 50 percent, further reducing costs and environmental impact.
Boost productivity: Productivity is increased with a business-quality print speed of 15 black and 7.1 colour pages per minute (ISO/IEC 24734)2 and up to 38 pages per minute in draft3 mode. With no warm-up time required, results are delivered at high speed, and a high-capacity 250-sheet front-loading paper tray means less time is spent refilling.
Easy access: A straightforward and easy to use printer, the B42WD has built-in Wi-Fi and Ethernet connectivity.
Built for business: Business documents of all types can be printed with confidence with Epson's DURABrite Ultra Ink, delivering sharp, laser-like text and vibrant colours, with a finish which is water, smudge, fade and highlighter resistant.
Economical printing
This is a printer designed to save time and money while delivering high-quality professional results. It is affordable and cost-per-page is up to 50 percent lower than competitive laser printers1. Costs are kept low as Epson's individual ink cartridge system means only the color used needs to be replaced, while further savings can be made thanks to a choice of different cartridge sizes including XL 'Stag' inks for high volume, low-cost printing. Automatic duplexing helps to cut paper usage by up to 50 percent, further reducing costs and environmental impact. -
Boost productivity
Productivity is increased with a business-quality print speed of 15 black and 7.1 color pages per minute (ISO/IEC 24734)2 and up to 38 pages per minute in draft3 mode. With no warm-up time required, results are delivered at high speed, and a high-capacity 250-sheet front-loading paper tray means less time is spent refilling. -
Easy access
A straightforward and easy to use printer, the B42WD has built-in Wi-Fi and Ethernet connectivity. -
Built for business
Business documents of all types can be printed with confidence with Epson's DURABrite Ultra Ink, delivering sharp, laser-like text and vibrant colors, with a finish which is water, smudge, fade and highlighter resistant.
- Epson Stylus Office B42WD - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 4.5 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 38 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Automatic Duplexing
- Interface
- USB, LAN, Wi-Fi(n)
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 250 sheets
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 44.5 cm x 33 cm x 15.4 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
- Minimum Ink Droplet Size
- 2 pl
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1440 dpi
- 5760 x 1440 dpi
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, 130 x 200 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 250 sheets
- Networking
- Print server
- Data Link Protocol
- WEP, WPA-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Connections
- 1 x USB 2.0 - 4 pin USB Type A , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- Power Device
- Power supply - internal
- 16 Watt
- Power Consumption Stand by / Sleep
- 3 Watt
- Software Included
- EPSON Easy Photo Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Operating)
- 40 dBA
- 44.5 cm
- 33 cm
- 15.4 cm
- 4.5 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £16.73 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £12.18 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.32 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.73 |
