Epson Perfection V750 Pro
Customer rating: 3.0* (Write a review)
Quicklinx: 42HBWS00 Mfr#: B11B178071CA
The Epson Perfection V750 Photo is the ideal scanner for photo enthusiasts and advanced amateur photographers. Featuring Epson's unique Dual Lens System combined with DIGITAL ICE Technologies it delivers exceptional quality film and photo scanning.
Epson Perfection V750 Pro - flatbed scanner - desktop - USB 2.0, FireWire
Flatbed scanner - desktop
Interface Type
USB 2.0, FireWire
Scanning Sensor Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
Optical Resolution
6400 dpi x 9600 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Transparencies, plain paper, film
Document Feeder Type
Manual
AC 120/230 V
Microsoft Windows XP Home Edition, Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 Professional / XP Professional, Apple MacOS X 10.2 or later, Microsoft Windows XP Professional x64 Edition
Microsoft Certification
Certified for Windows Vista
30.8 cm x 50.3 cm x 15.3 cm
6.6 kg
Interface Type
USB 2.0, FireWire
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Scan Mode
Single-pass
CCD
Bulb / Light Source Type
Scan Density Range
4.0D
Scanner Speed Details
11 sec/scan - black & white - A4 - 300 dpi , 12 sec/scan - colour - A4 - 300 dpi , 20 sec/scan - colour - A4 - 600 dpi , 35 sec/scan - film (negatives) - 35mm - 2400 dpi , 36 sec/scan - film (positives) - 35mm - 2400 dpi
Scanner Features
Digital ICE Technology, Dual Lens System
Media Handling
Max Document Size
216 mm x 297 mm
Manual
Interfaces Details
USB - Type B , FireWire - 6 pin FireWire
Transparency adaptor, film holder
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
AC 120/230 V
Power Consumption Operational (Standby)
32 Watt (19 Watt)
Software Included
SilverFast Ai 6, Adobe Photoshop Elements 3.0, ABBYY FineReader 6.0 Sprint Plus
30.8 cm
50.3 cm
15.3 cm
6.6 kg
5 °C
35 °C
10 - 80%
Customer reviews
Write a review for the Epson Perfection V750 Pro here!
Excellent results but V700 much cheaper
Reviewed by Steve. Review Posted 28/09/2007
I bought the V750 pro to allow me to scan negatives mainly as it allows you to use fluid mounts so that you get better scans but I found that it's not that easy to get rid of the tiny air bubbles. It took ages to get good quality scans using the fluid mounts and I regret not buying the much cheaper V700 that, as far as I can see, only misses out on the liquid mount option. Excellent scanning otherwise but I'd recommend the V700 as a better buy.
  • Overall 3*
  • Ease of use 4*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
