A4 photo scanner
Epson ReadyScan LED technology delivers scans instantly with virtually no warm-up time, and is very power-efficient, helping to reduce your energy bills and impact on the environment.
Scanning bulky books or 3D objects is no problem, as the Perfection V37's lid has an extendable hinge than can open up to 180 degrees. Even if parts of the book or object being scanned are not in contact with the scanner's glass, they will still be in focus and captured accurately. This is because Epson's CCD image sensor technology offers a greater depth of field than the CIS (contact image censor) technology used in most comparable scanners.
Simple to use, the Perfection V37 enables you to conveniently scan to email at the touch of a button, or scan to multi-page, searchable PDF. Other useful photo and document editing features are available using the included software: Epson Easy Photo Fix makes it easy to bring your originals back to life by restoring faded colour, removing the appearance of dust and scratches and adjusting backlight; Optical Character Recognition (OCR) allows you to copy, paste and edit text from scanned documents; and Epson Document Capture enables direct scanning to cloud storage services, so you can access your scans from any computer or mobile device.
High resolution
4,800dpi for superior quality
Versatile
Scan photos, documents, scrapbooks
Flexible
Scan bulky books and 3D objects
Convenient
Scan to email or cloud storage
No warm-up time
Saves power and money
A4 photo scanner
High-resolution, superior-quality A4 scanner ideal for photos, documents and scrapbook pages.
- Epson Perfection V37 - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Light Source
- LED
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 48-bit colour
- Optical Resolution
- 4800 dpi x 9600 dpi
- Max Document Size
- 210 mm x 297 mm
- Supported Document Type
- Plain paper, bulk objects (such as books, magazines and other bound materials), photo
- Document Feeder Type
- Manual
- Power
- AC 230V (50/60 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Apple MacOS X 10.3 or later, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
- Microsoft Certification
- Compatible with Windows 7
- 28 cm x 43 cm x 4.1 cm
- 2.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 48-bit colour
- Bulb / Light Source Type
- LED
- Scan Density Range
- 3.2D
- Scanner Features
- EPSON ReadyScan LED Technology, Text Enhancement, RGB Color Dropout
Media Handling
- Max Document Size
- 210 mm x 297 mm
- Manual
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 12 Watt (3.7 Watt)
- Software Included
- EPSON Scan, EPSON Copy Utility, ABBYY FineReader 9.0 Sprint, EPSON Document Capture Pro, ABBYY FineReader 8.0 Sprint for MAC
- OS Required
- 28 cm
- 43 cm
- 4.1 cm
- 2.2 kg
- Limited warranty - 1 year - carry-in
- 5 °C
- 35 °C
- 10 - 80%
