Epson Expression Home XP-605 - Multifunction- Wifi - Colour - Inkjet - 32ppm
Quicklinx: 8HW2WS00 Mfr#: C11CC47321
Compact and versatile
Epson's Expression Premium XP-605 1 is perfect for home users who are interested in printing photos and need a Wi-Fi printer that can print glossy photos and crisp, clear text documents. This printer is an impressive 40 percent smaller than previous models. It also boasts intelligent features such as fast duplex printing, dual paper trays and Epson Connect - for versatile, user-friendly printing.
Claria premium ink produces crisp, clear text documents and outstanding, glossy photos with sharp detail, deep blacks and rich, vibrant colors. It offers a perfect balance for the modern home. Epson Connect allows you to print wirelessly from smartphones and tablet PCs within the home, and print from anywhere in the world by emailing documents directly to the printer's unique email address. The remote printer driver offers more flexibility to print from your PC to any Epson Connect printer anywhere in the world, while Scan-to-Cloud enables you to store scanned documents directly in cloud services. In addition the XP-605 is AirPrint and Google Cloud print ready.
Setting up the XP-605's Wi-Fi connection is easy with its automatic Wi-Fi set-up. The printer automatically finds the relevant connection settings in order to configure itself. Dual front-loading paper trays allow you to choose between photo and A4 printing. You can also fill both paper trays with photo paper to further increase your photo printing output.
The 6.3 cm color LCD screen with smart-navigation touch-panel highlights relevant buttons, guiding you through the printing process, while the PictBridge and memory card slots offer greater flexibility for PC-free photo printing. This printer will also print directly onto suitable CDs and DVDs so you can personalize family films and digital photo albums to create the ideal gift.
Wi-Fi all-in-one
Print, scan, copy
Ultra compact
40% smaller than previous models
Epson Connect
Freedom to print and scan anywhere
Easy operation
6.3cm smart-navigation LCD screen
Versatile
CD and DVD printing
Epson Expression Premium XP-605 - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo
Max Printing Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD disc
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card
AC 230 V (50/60Hz)
39 cm x 34.1 cm x 13.8 cm
7.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Ink-jet - colour
AirPrint Enabled
Supported Flash Memory
SD Memory Card, Memory Stick Duo, MicroSDHC, Memory Stick Micro (M2), Memory Stick PRO Duo, MicroSD, SDHC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
360 nozzles (black), 180 nozzles (per colour)
Max Printing Speed
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, photo black
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Premium Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 12 ppm - B/W (ISO/IEC 24734) , Printing: up to 9 ppm - colour (ISO/IEC 24734)
1 x USB 2.0 , 1 x USB host
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.8 or later, MS Windows 8
Software Included
Epson Event Manager, EPSON Print CD, Epson Easy Photo Print, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for Mac
AC 230 V (50/60Hz)
18 Watt
Power Consumption Sleep
2 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
39 cm
34.1 cm
13.8 cm
7.1 kg
Shipping Width
47.9 cm
Shipping Depth
23.5 cm
Shipping Height
42.7 cm
Shipping Weight
9.4 kg
8HW2 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £16.37
8HW2 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.78
8HW2 Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.78
8HW2 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £15.22
