Epson ELPDC07 Digital Document Camera
Quicklinx: DP6XWS00 Mfr#: V12H759040
18 In Stock
£180.47 ex VAT
£216.56 inc VAT
See in great detail
Share high-quality visuals including detailed diagrams and textbook pages with a Full HD 1080p output and 8x digital zoom. You can even adjust the height and rotate the camera 90 to accommodate 3D objects. For science lessons, the supplied microscope attachment can also be used to unveil fascinating microscopic worlds in real-time.
Effortless to use
Minimise preparation time with this high-tech, compact and affordable portable solution, that makes it quick and easy to enlarge source material. In just seconds, you can connect directly to the latest Epson projectors using the two in one USB cable connection which provides power and transmits the video signal.
Highly portable, modern design
The Epson ELPDC07 visualiser is neat and compact, it features LED illumination, a built-in microphone and doesn't need a separate power supply. It's also light and easy to carry in the included carry case, with the arm folding neatly down into the base. Needing just 2.5W, you can be sure that its power consumption meets modern energy conservation requirements .
  • Portable visualiser
    Quick to set-up visualiser for magnifying source material clearly and easily for the benefit of everyone in the classroom.
Epson ELPDC07 - digital document camera
Digital document camera
26 cm x 7.6 cm x 38.8 cm
1 kg
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.7" - 2 MP
Focus Adjustment
Automatic
USB 2.0
1 - USB cable
Digital image rotation, brightness control, built-in LED illuminator, microscope image mode
5-year warranty
Wired
26 cm
7.6 cm
38.8 cm
1 kg
Camera
Max Digital Video Resolution
1920 x 1080
Digital Zoom
8
Frame Rate (max)
Image Sensor
2 MP CMOS 1/2.7"
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
Ports
USB 2.0 - 4 pin USB Type B
Carrying case
1 x USB cable
Software Included
Epson Easy Interactive Tools
Limited warranty - 5 years
Brand: Epson
