Epson ELPDC06 Document Camera USB
5 YEAR WARRANTY!!!
Quicklinx: 7339WS00 Mfr#: V12H321003
Innovative, flexible and easy to use
Incorporating our advanced technologies, the Epson ELP DC-06 is a compact and affordable desktop solution for enlarging the source materials you can display while drastically cutting preparation time. The Epson ELP DC-06 visualiser only takes seconds to set up. You can connect directly to the new Epson EB-8 projector series and future Epson projectors thanks to the direct USB connection and two-in-one cable. It also lets you work via a computer. Just plug in, unfold the arm and you´re ready to focus.
Highly portable, modern design
The Epson ELP DC-06 visualiser does not need a separate power supply, making it very compact. It is light, and the arm folds down neatly into the base making it easy to carry. With power consumption of less than 2.5W it meets modern ecological standards.
Lively presentations
Visual quality is guaranteed with 2 million pixel resolution and powerful zoom allowing you to focus on details. The camera can be turned 90° in different axis and the height adjusted, so you can even capture 3D objects, or an entire board.
  • Innovative, flexible and easy to use
  • Highly portable, modern design
  • Lively presentations
Epson DC-06 Document Camera - digital document camera
Digital document camera
26 cm x 7.6 cm x 38.8 cm
0.99 kg
Wired
Camera
Frame Rate (max)
15 frames per second
Optical Sensor Type
CMOS - 1/3" - 2 MP
Focus Adjustment
Automatic
Lens Iris
F/2.8
USB
1 - USB cable - external
Digital image rotation, digital image freeze, auto white balance
Environmental Parameters (operating)
5 °C - 35 °C; 20 - 80% relative humidity
Wired
26 cm
7.6 cm
38.8 cm
0.99 kg
Camera
Digital Zoom
4
Frame Rate (max)
Still Image Capture Resolution
1024 x 768
Image Sensor
2 MP CMOS 1/3"
Lens Construction
Lens Iris
F/2.8
Focus Adjustment
Automatic
Computer Interface
USB
Interfaces Details
1 x USB - 4 pin USB Type B
1 x USB cable - external
5 °C
35 °C
Relative Humidity (operating)
20 - 80%
