Epson EH-TW6100W Full HD Home Cinema Projector
Quicklinx: 8LB2WS00 Mfr#: V11H502041LU
The EH-TW6100W delivers a 40,000:1 contrast ratio and is enhanced by Epson's 3LCD technology to provide superb quality images. An equally high White and Colour Light Output of up to 2,300 lumens means you can watch content during the day, without sitting in the dark.
Connect your WiHD devices directly to the projector, or alternatively plug your non-WiHD devices into Epson's HD transmitter. Five HDMI inputs connect different devices, which you control with a single remote. 'Real time' Wireless HD connection ensures content is shown without delay or picture lag.
3D content is noticeably bright thanks to Epson's luminance enhancement technology. A simple press of a button converts 2D high definition films and video games into 3D, so you can experience even more 3D content. Featuring a pair of lightweight, rechargeable Radio Frequency (RF) active shutter 3D glasses, included with the projector, you can enjoy content without interference. You can keep these industry standard glasses for future upgrades, and use them with other home projector and TV manufacturers.
Thanks to the 3D depth adjustment function, depth perception and image quality is much more enhanced than previous Epson 3D projectors. With five different colour modes and an auto-colour optimiser, you can enjoy your content rather than adjusting the menu settings.
  • Big screen experiences
    Wireless Full HD cinematic experiences for bright, high definition 2D and 3D home cinema, gaming and sports, with one pair of RF 3D glasses.
Epson EH-TW6100W - 3LCD projector - 3D
3LCD projector - 1080p
3D Capable
Yes (3D glasses included)
Built-in Devices
Stereo speakers
Brightness
2300 lumens
Contrast Ratio
40000:1 / 40000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
Speakers
Speaker(s) - integrated
358 Watt
42 cm x 36.5 cm x 13.7 cm
6 kg
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
2300 lumens
Contrast Ratio
Image Size
76 cm - 762 cm
Projection Distance
0.9 m - 14.5 m
Throw Ratio
1.32 - 2.15:1
Resolution
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
6-segment colour wheel, Side-by-Side, EPSON Super White, EPSON 3LCD technology, EPSON Cinema Filter, Crystal Clear Fine (C2 Fine), Split Screen, Wireless 3D HD function, Dynamic Mode, Theater Mode, 480hz 3D drive
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x component video input - RCA x 3 , 2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x USB 2.0 - 4 pin mini-USB Type B
Cable cover, 3D Sync transmitter, 3D active glasses charging adapter, wireless remote control
Security Features
358 Watt
Power Consumption Operational (Standby)
0.35 Watt
42 cm
36.5 cm
13.7 cm
6 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 2000 hours
5 °C
35 °C
Sound Emission
32 dBA
24 dBA
