Epson EH-TW6100 Full HD 3D Home Cinema Projector
Quicklinx: 8L9ZWS00 Mfr#: V11H501040LU
The EH-TW6100 delivers a 40,000:1 contrast ratio and is enhanced by Epson’s 3LCD technology to provide superb quality images. An equally high White and Colour Light Output of up to 2,300 lumens means you can watch content during the day, without sitting in the dark.
With five different colour modes and an auto-colour optimiser, you can enjoy your content rather than adjusting the menu settings. You can easily align projections with horizontal and vertical keystone correction to ensure a straight and correct image, and also use the split-screen function to watch two sources at the same time.
The front facing ventilation system with low-noise fan means you are not subjected to distracting, uncomfortable hot air while watching content. The two embedded 10W speakers support content, while photos of past holidays and outings can be easily displayed using the slideshow function.
3D content is noticeably bright thanks to Epson’s luminance enhancement technology. A simple press of a button converts 2D high definition films and video games into 3D, so you can experience even more 3D content. Thanks to the 3D depth adjustment function, depth perception and image quality is much more enhanced than previous Epson 3D projectors. Featuring a pair of lightweight, rechargeable Radio Frequency (RF) active shutter 3D glasses, included with the projector, you can enjoy content without interference. You can keep these industry standard glasses for future upgrades, and use them with other home projector and TV manufacturers.
  • Immersive audio experience
    With an output power of 10 W and stereo sound output mode, the built-in speakers deliver a rich, immersive audio experience that complements the visual performance.
  • Stunning visual clarity
    Featuring Full HD image format with a dynamic contrast ratio of 40,000:1 and brightness of 2300 lumens, this projector ensures vibrant and clear images, making it perfect for cinema use.
  • Flexible connectivity
    Equipped with multiple interfaces including HDMI, VGA, and composite video inputs alongside a USB 2.0 port, this projector offers versatile connectivity options for a wide range of devices.
  • Enhanced usability
    With both horizontal and vertical keystone correction and a zoom factor of 1.6x, setting up the projector is hassle-free, ensuring a perfectly proportioned image in various spaces.
  • Long-lasting performance
    The projector's lamp offers a life cycle of up to 4000 hours in normal mode and 5000 hours in economic mode, providing long-lasting performance for all your viewing needs.
Epson EH-TW6100 - 3LCD projector - 3D
3LCD projector - 1080p
3D Capable
Yes (3D glasses included)
Built-in Devices
Stereo speakers
Brightness
2300 lumens
Contrast Ratio
40000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s)
358 Watt
42 cm x 36.5 cm x 13.7 cm
6 kg
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
2300 lumens
Contrast Ratio
40000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.9 m - 14.5 m
Throw Ratio
1.32 - 2.15:1
Resolution
Native Aspect Ratio
16:9
Bulb type
E-TORL UHE 230 Watt
Bulb life cycle
6-segment colour wheel, EPSON Super White, EPSON 3LCD technology, EPSON Cinema Filter, Crystal Clear Fine (C2 Fine), Split Screen, Dynamic Mode, Theater Mode
Lens
Lens Aperture
F/1.51-1.99
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
1080p
Speakers
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x component video input - RCA x 3 , 2 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x 3D glasses - RJ-45 (management) , 1 x USB 2.0 - 4 pin mini-USB Type B
3D active glasses charging adapter, wireless remote control
1 x HDMI cable
Security Features
358 Watt
Power Consumption Operational (Standby)
0.35 Watt
42 cm
36.5 cm
13.7 cm
6 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 2000 hours
5 °C
35 °C
Sound Emission
32 dBA
24 dBA
