High quality projections: Harnessing Epson's latest technology, this projector delivers equally high White and Colour Light Output of 2,800 lumens and a high contrast ratio of 3,000:1, meaning high quality images are projected, even in daylight. Epson's 3LCD technology also ensures that images are clear, bright and easy on the eyes.
Easy set-up: The EH-TW480 is quick and simple to set up, thanks to its manual horizontal slider and automatic vertical keystone correction. Whatever the angle of the actual projector, you can easily align the projection to ensure a straight and correct image, great for settling down to watch a film, arranging online video games quickly or making sure you don't miss the beginning of important sports events.
Flexibility: With its wide range of connectivity options, you can easily watch a whole host of content from games consoles, Blu-ray and DVD players, PCs and TV set-top boxes. Anyone who wants to share holiday photos or create a slideshow can do it straight from their USB memory stick. The USB reader allows you to play photos and images straight away, with no need to connect to additional devices.
Great for gamers: If you're a keen gamer, you'll appreciate the specific video game colour mode, which greatly enhances gameplay so you won't have to fiddle with menu settings during gaming sessions.
Portable: The EH-TW480's slim, lightweight design means you can easily take the big screen experience wherever you go, whether it's in a different room or even a friend's house. Additionally, you'll be able to enjoy your HD-Ready content much longer with the lamp's long 5,000 hour lifespan.
Portable HD-Ready projector
The perfect portable companion for video games, movies and sports that is both easy to use and affordable.
- Epson EH-TW480 - 3LCD projector - portable
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 2800 lumens
- Brightness (Colour)
- 2800 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- E-TORL UHE 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 29.5 cm x 22.8 cm x 7.9 cm
- 2.3 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 2800 lumens
- 2800 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 83.8 cm - 808 cm
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- Bulb life cycle
- OSD Languages
- Danish, Hebrew, Hungarian, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian
- EPSON 3LCD technology
Lens
- Lens Aperture
- F/1.58-1.72
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type B , 1 x VGA / component video input - 15 pin D-Sub (DB-15) , 1 x USB - 4 pin USB Type A , 1 x audio line-in - RCA x 2
- Included Accessories
- Carrying case, wireless remote control
- Voltage Required
- 270 Watt
- Power Consumption Operational (Standby)
- 3.3 Watt
- 29.5 cm
- 22.8 cm
- 7.9 cm
- 2.3 kg
- Limited warranty - 3 years , Limited warranty - lamp - 3 years
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission (Economic Mode)
- 29 dB
Epson EH-TW480 Portable HD-Ready Projector
